MSP430F5132: How to use COMP_B resistor ladder to set reference voltage using CBREF0/1
Part Number: MSP430F5132
Hi Experts!
How can I use the resistor ladder to set my desired comparator reference voltage? I can't find in datasheet.
In section 32.2.6 of MSP430x5xx and MSP430x6xx Family User's Guide, there is a diagram of the Comparator_B resistor ladder controlled by CBREF1 and CBREF0:
How can I use CBREF1 and CBREF0 to achieve my desired comparator Vref?
I'm hoping for an equation like Vref0 = [CBREF0] * Vin and Vref1 = [CBREF1] * Vin or something.
The example code found below is the only example using the R-ladder (line 38). Unfortunately, this doesn't help me understand how to achieve a Vref0 or Vref1. Hoping for any clarification!
// MSP430F51x2 Demo - COMPB Toggle from LPM4; CompB in ultra low power mode
// 		Vcompare is compared against the Vcc*1/2
// Description: Use CompB and shared reference to determine if input 'Vcompare'
//    is high/low.  When Vcompare exceeds 0.5*Vcc CBOUT goes high and when
//    Vcompare is less than 0.5*Vcc then CBOUT goes low.
//    Connect P3.3/CBOUT to P1.0 externally to see the LED toggle accordingly.
//                 MSP430F51x2
//          --|RST      P1.1/CB1 |<--Vcompare
//            |        P3.3/CBOUT|----> 'high'(Vcompare>Vcc*0.5); 'low'(Vcompare<Vcc*0.5)
//            |            P1.0  |__| LED 'ON'(Vcompare>Vcc*0.5); 'OFF'(Vcompare<Vcc*0.5)
//  C.Sterzik/B.Nisarga
//  Texas Instruments Inc.
//  Dec 2009
//  Built with CCS v4 and IAR Embedded Workbench Version: 4.21
#include <msp430.h>
int main(void)
  WDTCTL = WDTPW + WDTHOLD;     // Stop WDT
  P3DIR |= BIT3;                // P3.3 output direction
  P3SEL |= BIT3;                // Select CBOUT function on P3.3/CBOUT
// Setup ComparatorB
  CBCTL0 |= CBIPEN+CBIPSEL_1;   // Enable V+, input channel CB1
  CBCTL1 |= CBMRVS;             // CMRVL selects the refV - VREF0
  CBCTL1 |= CBPWRMD_2;          // Ultra-Low Power mode
  CBCTL2 |= CBRSEL;             // VREF is applied to -terminal
  CBCTL2 |= CBRS_1+CBREF04;     // VCC applied to R-ladder; VREF0 is Vcc*1/2
  CBCTL3 |= BIT1;               // Input Buffer Disable @P1.1/CB1
  CBCTL1 |= CBON;               // Turn On ComparatorB
  __delay_cycles(75);           // delay for the reference to settle
  __bis_SR_register(LPM4_bits);             // Enter LPM4
  __no_operation();                         // For debug
Thank you!
