CCE and Redefine Error during Code Port
Other Parts Discussed in Thread: MSP430F249
I am working on porting code from an NEC chip to the MSP430F249. I am using CCE 3.2.2.1.8. During the "Linking" of the project, I receive several of the following errors for numerous functions that are declared. I imagine it has something to do with the fact that las.obj has the "comm_xmt_str" function already linked into it through a header file, but why is it choking when system.obj is linked. I know "xxx.h" files are included throughout the various files, but why is this causing an error? Is there any way to ignore this through the Linker setup.
error: symbol "comm_xmit_str" redefined: first defined in "./LAS.obj"; redefined in "./SYSTEM.obj"
  • This error is typically generated when the symbol has been defined in multiple source files. Where is "comm_xmit_str" defined, in a source file or a header file? Could you send code snippets of these 2 source files and what the build command looks like in the CCE build window?
  • I think you might have triggered a thought. It looks like all the functions this error is occurring on are ones that I have implemented a return call within the header file so I can slowly migrate each of the corresponding C files over. So for the comm_xmt_str function I have placed the following line in the comm.h header file to at least implement the function but not allow any erros.
    int
    comm_xmit_str (enum CommPort Port, char *buff){return(1);}
    'Building file: ../LAS.C'
    'Invoking: MSP430 Compiler v3.0'
    "C:/Program Files/Texas Instruments/CC Essentials v3/tools/compiler/MSP430/bin/cl430" --fp_reassoc=off --include_path="C:/Program Files/Texas Instruments/CC Essentials v3/tools/compiler/MSP430/include" --sat_reassoc=off --symdebug:dwarf --plain_char=unsigned --silicon_version=mspx --opt_level=3 --printf_support=full --asm_listing --preproc_with_compile --preproc_dependency="LAS.pp" "../LAS.C"
    "../LAS.C", line 349: warning: variable "mask" was set but never used
    'Finished building: ../LAS.C'
    'Building file: ../SYSTEM.C'
    "C:/Program Files/Texas Instruments/CC Essentials v3/tools/compiler/MSP430/bin/cl430" --fp_reassoc=off --include_path="C:/Program Files/Texas Instruments/CC Essentials v3/tools/compiler/MSP430/include" --sat_reassoc=off --symdebug:dwarf --plain_char=unsigned --silicon_version=mspx --opt_level=3 --printf_support=full --asm_listing --preproc_with_compile --preproc_dependency="SYSTEM.pp"
    'Finished building: ../SYSTEM.C'
