I write this code to set up the communication between msp430 launchpad and PC. First I send two bytes to MSP430 from tera term. If the two byes are 0x31,0x30, start the ADC convertion. After finishing convertion, send ADC convertion result back to PC(tera term).
When I send data from PC to MSP430, the UART works well. However, after sentence " while (!(ADC10IFG & ADC10CTL0));", the UART doesn't work well any more. When msp430 send 3 bytes, PC only receive 2 bytes and the value PC received is not equal to the bytes msp430 send.
Could you please tell me what could be the problem? Thanks a lot!!!
int main(void)
a=x=i=0;
Log1 = (void *) 0x1000;
Address = (char) 0x01;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
ADC10CTL1 = ADC10DIV_0 + INCH_10 + SHS_1 + CONSEQ_2; // TA trig., rpt, A10
ADC10CTL0 = SREF_1 + ADC10SHT_3 + REF2_5V + ADC10IE + REFON + ADC10ON;
if (CALBC1_1MHZ==0xFF) // If calibration constant erased
while(1); // do not load, trap CPU!!
DCOCTL = 0; // Select lowest DCOx and MODx settings
BCSCTL1 = CALBC1_1MHZ; // Set DCO
DCOCTL = CALDCO_1MHZ;
P1DIR = BIT0 + BIT6;
P1SEL = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
P1SEL2 = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
UCA0CTL1 |= UCSSEL_2; // SMCLK
UCA0BR0 = 104; // 1MHz 9600
UCA0BR1 = 0; // 1MHz 9600
UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
IE2 &= ~UCA0TXIE;
__bis_SR_register(LPM0_bits + GIE); // Enter LPM0, interrupts enabled
// Echo back RXed character, confirm TX buffer is ready first
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
Received[i] = UCA0RXBUF;
i++;
if(i==2)
i = 0;
if(Received[1] == 0x31 && Received[0] == 0x30)
flash_eraseWord(Log1);
Log1++;
b++;
Log1 = (void*) 0x1000;
TACCTL1 = OUTMOD_4; // Toggle on EQU1 (TAR = 0)
TACTL = TASSEL_2 + MC_2; // SMCLK, cont-mod
ADC10CTL0 |= ENC;
while (!(IFG2 & UCA0TXIFG));
UCA0TXBUF = Address;
FirstADCVal = ADC10MEM;
ADC10CTL0 &= ~ENC;
Byte1 = (char) (FirstADCVal >> 8);
Byte0 = (char) FirstADCVal;
flash_writeWord(Log1, Byte0);
Log1++;
flash_writeWord(Log1, Byte1);
UCA0TXBUF = Byte0;
UCA0TXBUF = Byte1 ;
LPM0_EXIT;
a++;
