Can not write the data on same address in information memory(flash)
Other Parts Discussed in Thread: MSP430F2370
I am not able to write data 2 times on the same address,
I am trying to write 0x05 and 0x07 one after another on 0x1042.
But at the end data i found on 0x1042 is 0x05,instead of 0x07.
I am trying this code on MSP430F2370.
Code:
    WDTCTL = WDTPW + WDTHOLD;            // stop watchdog timer
    Flash_ptr = (unsigned char *) 0x1042;
    BCSCTL1 = CALBC1_1MHZ;                    // Set DCO to 1MHz
    DCOCTL = CALDCO_1MHZ;
    FCTL2 = FWKEY + FSSEL0 + FN1;             // MCLK/3 for Flash Timing Generator
    while(FCTL3 & 0x0001 == BUSY);
    FCTL3 = FWKEY;                            // Clear Lock bit
    FCTL1 = FWKEY + WRT;                      // Set WRT bit for write operation
    *Flash_ptr = 0x05;                   // Write value to flash
    FCTL1 = FWKEY;                            // Clear WRT bit
    FCTL3 = FWKEY + LOCK;
    _delay_cycles(9000000);
    *Flash_ptr = 0x07;                   // Write value to flash
     while(1);
