Part Number: MSP430FR6989
Hello, I'm working on a program in which a push-button press will write a value stored in the variable 'data' to FRAM using the driverlib function FRAM_memoryFill32. I've been debugging with a watch window open to track the variables 'press' and 'data'. Upon the first button press, the interrupt is enabled and the first value of 'data' is written to memory. However, upon subsequent button presses, the value stored in 'data' is no longer rewritten, and is reset back to zero. 'press' is also reset back to zero. Here is my code:
#include "driverlib.h"
#include "msp430.h"
#include "intrinsics.h"
#include "stdio.h"
#define FRAM_TEST_START 0x4800 // Define initial location in FRAM as address 0x4800
unsigned int press = 0; // Initialize variable 'press'
uint32_t data = 0; // initialize 32-bit 'data' variable
int main(void) {
WDT_A_hold(WDT_A_BASE); // Stop Watchdog Timer
PMM_unlockLPM5(PMM_BASE); // Unlock pins
GPIO_setAsInputPin(GPIO_PORT_P1, GPIO_PIN1); // Set P1.1 as input
GPIO_setAsInputPinWithPullUpresistor(GPIO_PORT_P1, GPIO_PIN1); // Set P1.1 pull-up resistor
GPIO_interruptEdgeSelect(GPIO_PORT_P1, GPIO_PIN1,
GPIO_HIGH_TO_LOW_TRANSITION);
GPIO_enableInterrupt(GPIO_PORT_P1, GPIO_PIN1); // Enable interrupts on P1.1
GPIO_clearInterruptFlag(GPIO_PORT_P1, GPIO_PIN1); // Clear interrupt flag on P1.1
GPIO_setAsOutputPin(GPIO_PORT_P1, GPIO_PIN0); // Set P1.0 as output
GPIO_setOutputLowOnPin(GPIO_PORT_P1, GPIO_PIN0); // Initialize P1.0 as low
GPIO_setAsOutputPin(GPIO_PORT_P9, GPIO_PIN7); // Set P9.7 as output
GPIO_setOutputHighOnPin(GPIO_PORT_P9, GPIO_PIN7); // Initialize P9.7 as high
FRAM_memoryFill32(FRAM_BASE,data,(uint32_t*)FRAM_TEST_START,128);
//Enter LPM3
__bis_SR_register(LPM0_bits+GIE); // Enter LPM0
//__no_operation();
// ISR for pushbutton P1.1
#pragma vector=PORT1_VECTOR
__interrupt void Port_1(void)
// debouncing
__delay_cycles(64000); // Wait 64000 cycles
if ((P1IN & BIT1) != BIT1) {
press += 1; // Increment pushbutton count
if (press < 10 & press > 0) {
data += 0x00010001;
else {
press = 0;
data = 0x00000000;
GPIO_toggleOutputOnPin(GPIO_PORT_P1, GPIO_PIN0); // Toggle both output LEDs
GPIO_toggleOutputOnPin(GPIO_PORT_P9, GPIO_PIN7);
