EVM430-I2040S: Serial communications: Isolated RS232 & UART
Part Number: EVM430-I2040S
Other Parts Discussed in Thread: CC3200, TRS3122EEVM, TIDM-TWOPHASEMETER-I2040, MSP430I2040
I'll be using the EVM430-I2040S in a project where we'll be connecting the EVM to another microcontroller (CC3200) to relay the power/energy data measured.
The EVM has 2 options for communication: the isolated R232 (DB9) port, and the non-isolated serial connection.
Is there any way we can use the isolated RS232 port for 3.3V serial communication? I've looked at the schematic, and is the diode-capacitor-transistor arrangement between the DB9 connector & optocouplers some sort of charge pump?
RS232 voltages can be anywhere between 3 & 25V, and typical systems use around ~12V. What are the voltages we can expect on the DB9 connector?
  • Hello Avner,
    Thank you for your post.
    Yes, this would have to be implemented on the CC3200 side where the RS232-level signals would need to be converted down to 3.3V.
    Yes, since the highest supply voltage on the EVM430-I2040S is only 3.3V, these components raise the voltage to the RS232 voltage levels and reduce the voltage down to UART levels. Now, this design uses discrete components to achieve this, but keep in mind that we offer devices that integrate everything into a single package, such as the TRS3122 which is a 2Tx/2Rx Low Voltage, Low Power RS232 Transceiver. To help with your development, you could use the TRS3122EEVM, which converts RS232 signals down to 1.65 V up to 5.5 V, to connect to the CC3200. Another alternative for development could be the following two RS232-to-UART converters:
    For your final design, I would not use RS232 but instead use isolators on the UART interface between the MSP430i2040 and the CC3200. For example, the TIDM-TWOPHASEMETER-I2040 has a host processor with isolators between it and the MSP430i2040. I would recommend referring to this design and layout.
    I measured around +/-12V on the EVM430-I2040S.
    James
    MSP Customer Applications
