Part Number: MSP430FR2000
When the code starts I am planning to turn ON a switch (at P1.7). Then an interrupt at P1.3 should OFF the switch and turn ON RTC. With RTC interrupt switch should turn ON. Repeat. I am unable to make it work. I am unable to understand when MCU wakes up of LPM3.5 does the whole main code repeat or only some part of it. Does the ISR be executed first or after executing the main.
Prudhvi Sagar
#include <msp430.h>
int main(void)
WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
// Configure GPIO
P1OUT = 0x00; // Clear P1.0 output latch /P1.3 Pulldown
P1DIR = ~BIT3; // Set P1.3 to input direction
P2OUT = 0x00; // Unused pins to LP State
P2DIR = 0xFF;
P2SEL1 = BIT6 | BIT7; // P2.6~P2.7: crystal pins
SYSCFG0 = FRWPPW; // Enable FRAM write access
PM5CTL0 &= ~LOCKLPM5; // Disable the GPIO power-on default high-impedance
// mode to activate previously configured port settings
do
CSCTL7 = 0; // Clear XT1 fault flag
SFRIFG1 = 0; // Clear fault flag
} while (SFRIFG1 & OFIFG); // Test oscillator fault flag
if (SYSRSTIV == SYSRSTIV_LPM5WU) // When woken up from LPM3.5, reinit
__enable_interrupt();
else
// Device powered up from a cold start.
P1REN = BIT3; // P1.3 pull-down register enable
P1IES = 0x00; // P1.3 Low/High edge
P1IE = BIT3; // P1.3 interrupt enabled
CSCTL4 = SELA__XT1CLK; // Set ACLK = XT1CLK = 32768Hz...CHANGE: initial for use internal clock REFO
P1OUT ^= BIT7; //Turn on switch
__bis_SR_register(LPM3_bits | GIE); // Enter LPM3, enable interrupt
* RTC interrupt service routine
//CHANGE: Keep switch ON and wait indefinitely unitl GPIO interrupt
#pragma vector=RTC_VECTOR
__interrupt void RTC_ISR(void)
switch(__even_in_range(RTCIV,RTCIV__RTCIFG))
case RTCIV__NONE: break; // No interrupt
case RTCIV__RTCIFG: // RTC Overflow
P1OUT ^= BIT5;
P1IE = BIT3; // Enable RTC STart Interrupt
RTCCTL = RTCSS_2 | RTCSR | RTCPS__1024; //Stop RTC
// Enter LPM3.5 mode with interrupts enabled. Note that this
//operation does not return. The LPM3.5 will exit through a
//RESETevent, resulting in a re-start of the code.
PMMCTL0_H = PMMPW_H; // Open PMM Registers for write
PMMCTL0_L |= PMMREGOFF; // and set PMMREGOFF
__bis_SR_register_on_exit(LPM3_bits | GIE);
//__no_operation();
break;
default: break;
* Port 1 interrupt service routine
//Every interrupt turn switch OFF....Start RTC....Enter LPM
#pragma vector=PORT1_VECTOR
__interrupt void Port_1(void)
timeIncrement = 0; //Clear Software Counter
P1OUT ^= BIT7; //Turn OFF switch
RTCMOD = (32-1)*10;
// Source = XT1, divided by 1024, Start RTC
RTCCTL = RTCSS_2 | RTCSR | RTCPS__1024 | RTCIE;
P1IE = 0x00;
P1IFG = 0x00; //Clear P1.3 IFG
//operation does not return. The LPM3.5 will exit through a RESET
//event, resulting in a re-start of the code.
//__no_operation();
