Other Parts Discussed in Thread: EVM430-FR6043
I purchased the EVM430-FR6047 and the transducers AW5Y0980K04L193Z from Audiowell. I am making some tests for water metering with the transducers placed outside the pipe.
In the tests with PVC pipes I had quite good results, but starting tests with metalic pipes (like the ones in home) I didn't receive any signal. I have compared with oscilloscope the received signals with PVC and Metalic pipes, and using the metalic ones there is no signal in the receiving transducer.
1. Have you tested the device with metallic pipes? There is something Imust take into account?
I think that my problem is that I need more power in the transmision signals, in order to receive something with different materials than PVC. Maybe it also would help to increase the number of rebounds with the "V" configuration of the transducers.
2. There is any way to amplify the transmision signals? What would you recomend to amplify it?
Thank you in advance, I will be waiting for your response.
Kind regards,
Ferran
