Other Parts Discussed in Thread: MSP430F5438
Does anyone know if the error described in UCS10 has been solved in latest MSP430F5438/A chip or if TI has plan on solving it in hardware?
Thanks.
Thanks.
Hmmm, the 54xxA errata sheet SLAZ057N listes UCS10 as resolved for silicon revision F but not for G. Same for several more. So I actually don't know what to believe.
My assumption is that the rows for rev F and G have been twisted and that rev G does not contain this erratum anymore.
This is a little confusing but RevF is newer than RevG.
RevG is the result of fab/process change to offload manufacturing for RevE. This happened concurrently to the creation and release of the new RevF, so the factory took the next letter.
In other words:
- RevE = RevG
- RevF is newer with more bug fixes (including UCS10).
- RevH - when/if available - will be based on RevF.
Luis R
The non-As are marked "not for new design", so I guess there will be no more fixes applied.Kevin Song said:Does TI has any working on fixing UCS10 on non-A version?
Jens-Michael Gross said:The non-As are marked "not for new design", so I guess there will be no more fixes applied.Does TI has any working on fixing UCS10 on non-A version?[/quote]
That is correct, we don't have any plans to create a new Rev of F5438. The device continues to be in production but TI does not recommend using the F5438 for new designs. The F5438A is not an exact equivalent but it provides a good option for replacement.
Not that I know of. The A is a different product, not a new (bugfixed) revision. The two coexisted and are still coexisting.Kevin Song said:Is there any program / procedure provided by TI for user company to replace the existing stock of non-A version to A version chip considering this UCS10 error?
However, thr non-A always was significantly cheaper than the A version. (and AFAIK still is - I didn't check lately)
