We are reading incorrect voltages at certain test points and we are investigating if they are caused by the MSP-Gang programmer.
TI Could you please answer a few questions concerning MSP-Gang Programmer:
1. How is this voltage level set when an external power supply is used to power the target?
a. It is not clear how VTIO is set to match the voltage on Vext
2. What happens when some targets are using one voltage level and other targets are using a different voltage level?
a. Will VTIO adjust depending on which target is being programmed?
b. Is this handled within TI’s GUI?
3. What logic level does VTIO go to when the programming process is complete?
a. Is there a way to set VTIO_EN from the GUI to turn off VTIO?
i. Does it do this automatically or is there a manual setting to turn off VTIO?
b. What happens to VTIO when the GUI is closed?
Richard
