Other Parts Discussed in Thread: BQ32000
Hi
this is the working code for BQ32000 interfacing to msp430.
Nandish
Hi
Nandish
MainClockInit() statement inside your main() block is giving an error.
The error is :
unresolved symbol MainClockInit, first referenced in ./main.obj
I'm new to I2C so I used your code and I have no idea how to correct this. Any help is appreciated.
Hi bhaskar,
sorry i forgot to remove that line in my code and please find the below code which is tested . `
Nandish H S said:Hi bhaskar,
#include "MSP430.h"unsigned char sec, min, hour, month, year, date;#define SLA_ADR 0x68//slave addressvoid BQ32000Init(void);void BQ32000ReadTime(unsigned char *datos);void USCIB0Init(void);void I2CStop(void);unsigned char I2CStartWrite(unsigned int slave, unsigned char firstdata);unsigned char I2CStartRead(unsigned int slave);unsigned char I2CWrite(unsigned char c);unsigned char I2CRead(void);int main( void ){unsigned char datos[8];WDTCTL = WDTPW + WDTHOLD;BQ32000Init();__delay_cycles(250000);//250msegwhile(1){BQ32000ReadTime(&datos[0]);sec=datos[0];min=datos[1];hour=datos[2];date=datos[4];month=datos[5];year=datos[6];}}void BQ32000Init(void){USCIB0Init();I2CStartWrite(SLA_ADR,0x00);I2CWrite(0x30);//s 0I2CWrite(0x02);//m 1I2CWrite(0x10);//h 2I2CWrite(0x02);//day 3I2CWrite(0x11);//d 4I2CWrite(0x11);//mth 5I2CWrite(0x14);//y 6I2CWrite(0x10);//cotrol register 7I2CStop();}void BQ32000ReadTime(unsigned char *datos){unsigned char aux;USCIB0Init();I2CStartWrite(SLA_ADR,0x00);I2CStartRead(SLA_ADR);for(aux = 0; aux < 7; aux++, datos++){//6*datos = I2CRead();}UCB0CTL1 |= UCTXNACK;I2CStop();*datos = I2CRead();__delay_cycles(15);//15I2CStop();}void USCIB0Init(void){P1SEL |= 0xC0;P1SEL2 |= 0xC0;UCB0CTL1 |= UCSWRST;UCB0CTL0 = UCMST+UCMODE_3+UCSYNC;UCB0CTL1 = UCSSEL_2+UCSWRST;UCB0BR0 = 10;UCB0BR1 = 0;UCB0I2COA = 0;UCB0I2CSA = 0;UCB0CTL1 &= ~UCSWRST;}void I2CStop(void){while((UCB0STAT & BUSY)!= 0);UCB0CTL1 |= UCTXSTP;}unsigned char I2CStartWrite(unsigned int slave, unsigned char firstdata){while((UCB0STAT & BUSY)!= 0);UCB0I2CSA = slave;UCB0CTL1 |= UCTR; // I2C TXUCB0CTL1 |= UCTXSTT;UCB0TXBUF = firstdata;while(!(IFG2 &UCB0TXIFG));if((UCB0STAT & UCNACKIFG)!=0){return 0;} else {return 1;}}unsigned char I2CStartRead(unsigned int slave){while((UCB0STAT & BUSY)!= 0);UCB0I2CSA = slave;UCB0CTL1 &= ~UCTR;UCB0CTL1 |= UCTXSTT;while((UCB0CTL1 & UCTXSTT)!= 0);if((UCB0STAT & UCNACKIFG)!=0){return 0;} else{return 1;}}unsigned char I2CWrite(unsigned char c){while((UCB0STAT & BUSY)!= 0);UCB0TXBUF = c;while(!(IFG2 &UCB0TXIFG));if((UCB0STAT & UCNACKIFG)!=0){return 0;} else{return 1;}}unsigned char I2CRead(void){unsigned char data;while((UCB0STAT & BUSY)!= 0);while(!(IFG2 & UCB0RXIFG));data = UCB0RXBUF;return data;}
