Re-programming pin on MSP430F5437A
Other Parts Discussed in Thread: MSP430F5437A
I need to re-programm 4.0 pin of MSP430F5437A. Now it's an output that write data on a SD card, but I need to change this, in order to make this pin a controller for +/- 5V. As the producter said, I installed CCS IDE for this purpose. They said that all repository is avaible from this link https://github.com/ShimmerResearch/shimmer3/tree/master/apps/BtStream
But I can't still find such pin or a fuction that decide what that pin do. Can you help me?
Nicolò
  • You can find the datasheet for the device on the product page (click on the linked MSP part number in your post). That document will tell you what functions port pin P4.0 can do.
    From the product page you can also find the MSP430F5xx Family User's Guide (slau208) that will describe the GPIO capability and register settings you would use.
    As far as modifying the source code, a brief scan through the main.c file suggests that the current configuration of that pin is buried in a lower-level driver somewhere. You will need to dig for that and make the appropriate changes.
