Other Parts Discussed in Thread: MSP430F2012
Hi all !
I have some issues programming MSP430F2012 uC using 2-wire JTAG by MSP-FET430UIF tool. Programming (on automatic test bench, via spring test probes) on some uC (not all, because many program without any problem), MSPFlasher give me Error 16 Device unknown. I tried to update tool firmware but didn't solve.
I tried mspfetcom tool and MSPFlasher too but both can't program. On the circuit TEST pin is connected to programmer via a 1k resistor, while RESET pin is shared with an ATMega64 uP and connected to programmer via a 100R resistor.
Power supply is gived externally by the board under test and the command line I use for both tools are the follow:
mspfetcon +epv Filename -jtag_if=1 -FET=TIUSB
MSP430Flasher -m SBW2 -s -n MSP430F2012 -e ERASE_ALL -v -W Filename
or
MSP430Flasher.exe -e ERASE_ALL -v -w Filename
Anyone had this problem and solved it?
Thanks very much and have a good day.
Greetings, Devis
