MSP432P401R: BSL
Expert 1070 points
Part Number: MSP432P401R
Hi ,
Please help, My customer have problem with bootloader on his MSP4320LaunchPad.
Here is the actions I am doing:
  1. connected MSP432 LaunchPad to PC.
  2. Run BSL+Scripter.exe MSP432_uart.txt (see below)
  3. Observe error (see below)
MSP432_uart.txt -
//Script example MSP432 UART BSL
//Device : MSP432P401R
//Comm Bridge: XDS110 - MSP432LP BackChannelUART
// for this setting, the parity need to be
// set from Scripter side
// When MSP-BSL Rocket is used, parity will be
// generated by the Rocket
//Download blink application to
//MSP432 device through UART BSL
LOG
MODE P4xx UART 9600 COM6 PARITY
RX_PASSWORD_32 .\pass256_wrong.txt
RX_PASSWORD_32 .\pass256_default.txt
MASS_ERASE
RX_DATA_BLOCK_32 Blink_LED.txt
//RX_DATA_BLOCK_32 Blink_LED.hex
TX_BSL_VERSION_32
TX_DATA_BLOCK_32 0x0000 0x4000 ReadBlock_MSP432P401R.txt
//TX_DATA_BLOCK_32 0x0000 0x4000 ReadBlock_MSP432P401R.hex
REBOOT_RESET
Observe error
[ERROR MESSAGE]Initialization of BSL P432 failed! Exit the scripter!
      Maybe the problem has to do with how the BSL was invoked. The MSP432 BSL is invoked by any of the three following approaches. Any one of the conditions is a sufficient condition for BSL entry.
    1. The BSL is called by the bootcode when the application memory is erased. Bootcode reads out addresses 0x0 and 0x4 from the application flash memory and compares it with 0xFFFFFFFF to determine whether or not the application memory is erased.
    2. The BSL is called by application software
    3. The BSL is called by the device bootcode by applying a hardware entry sequence
    For more information on these approaches, please refer to the MSP432P401x Bootloader (BSL) User's Guide - Texas Instruments Section 4.3 BSL Invocation.
    Are you following any of these to invoke the BSL?? If not, please make to meet any of these conditions before running your actions listed above.
    Probably the easiest to accomplish is #1. You can do this with the factory reset, the factory reset will erase the device flash, therefore the BSL will be invoked.
      Hopefully this helps.
         David
    Customer try to do all of the steps you advise and he still received the error below,please help!
    Unfortunately the image did not come through. Could you please re-post.
    David
  • Hi there,
    I just retested the MSP432 Launchpad Rev B and Rev C on my Win 10 machine, and it is working. What I could suggest you to do is the following:
    1. make sure your device is empty. if you are using CCS, you can connect to the debug core, and then run the MSP432_Factory_Reset script.
    2. BSL on MSP432 has the timeout of 10 seconds, so reset the device before you start the BSL
    Let me know if this is still not working on your side.
  • ReadBlock_MSP432P401R.TXTHi ,
    I tried it again. It worked one time exactly with TI’s script example. Please see the log files.
    But now I could not re-program the evaluation board.
    It is blinking with the RED LED1 forever.
    And scripts not working again.
    What could you suggest?
    BSL Scripter 3.2.1
    PC software for BSL programming
    2017-Apr-19 14:53:50
    Input file script is : C:/CardiacX/MSP432/bootloader/MSPBSL_Scripter_win_v.3.02.01.00/MSPBSL_Scripter_win/ScriptExample/P4xx_uart/MSP432_uart.txt
    	Read Txt File  : C:\CardiacX\MSP432\bootloader\MSPBSL_Scripter_win_v.3.02.01.00\MSPBSL_Scripter_win\ScriptExample\P4xx_uart\pass256_wrong.txt
    	[ERROR_MESSAGE]BSL Password is error!
    	Read Txt File  : C:\CardiacX\MSP432\bootloader\MSPBSL_Scripter_win_v.3.02.01.00\MSPBSL_Scripter_win\ScriptExample\P4xx_uart\pass256_default.txt
    	BSL Password is correct!
    MASS_ERASE
    	Mass Erase is successful!
    	Read Txt File  : C:\CardiacX\MSP432\bootloader\MSPBSL_Scripter_win_v.3.02.01.00\MSPBSL_Scripter_win\ScriptExample\P4xx_uart\Blink_LED.txt
    	Time elapsed of writing 1982 bytes : 2.484 seconds
    	Speed of writing data :0.7793(kB/s)
    TX_BSL_VERSION_32
    	Vendor:[TI] CI:[0002] API:[0004] PI:[0103] Build-ID:[0004]
    	Write Txt File : C:/CardiacX/MSP432/bootloader/MSPBSL_Scripter_win_v.3.02.01.00/MSPBSL_Scripter_win/ScriptExample/P4xx_uart/ReadBlock_MSP432P401R.txt
    	Time elapsed of reading 16384 bytes : 20.31 seconds
    	Speed of reading data : 0.7877(kB/s)
    REBOOT_RESET
    Also this file
  • @0000
    00 00 01 20 7B 07 00 00 87 07 00 00 87 07 00 00
    87 07 00 00 87 07 00 00 87 07 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 87 07 00 00
    87 07 00 00 00 00 00 00 87 07 00 00 87 07 00 00
    87 07 00 00 87 07 00 00 87 07 00 00 87 07 00 00
    87 07 00 00 AD F1 20 0D B1 48 00 68 00 F4 E0 20
    00 0C 01 90 01 99 01 20 88 40 8D F8 08 00 AC 48
    00 68 00 F0 07 00 00 90 12 E1 AA 48 00 78 60 B3
    A9 49 46 F6 5A 10 08 60 A8 49 08 68 40 F0 01 00
    08 60 A5 49 01 20 08 60 A2 48 00 78 A0 B1 A4 48
    00 78 40 B1 9D F8 08 00 A2 49 4F F4 FA 32 B2 FB
    F0 F0 08 60 06 E1 9D F8 08 00 9E 49 4F F4 FA 42
    B2 FB F0 F0 08 60 FD E0 9D F8 08 00 99 49 4F F4
    00 42 B2 FB F0 F0 08 60 F4 E0 9D F8 08 00 95 49
    4F F4 00 42 B2 FB F0 F0 08 60 EB E0 9D F8 08 00
    90 49 42 F2 10 72 B2 FB F0 F0 08 60 E2 E0 8C 48
    00 78 40 B1 9D F8 08 00 8A 49 4F F4 FA 32 B2 FB
    F0 F0 08 60 D6 E0 9D F8 08 00 86 49 4F F4 FA 42
    B2 FB F0 F0 08 60 CD E0 83 48 00 68 6F F3 9F 20
    AD F8 18 00 11 E0 81 48 05 90 22 E0 80 48 05 90
    1F E0 80 48 05 90 1C E0 7F 48 05 90 19 E0 7F 48
    05 90 16 E0 7E 48 05 90 13 E0 77 48 00 68 10 F4
    E0 20 E8 D0 B0 F5 80 30 E8 D0 B0 F5 80 30 E8 D0
    B0 F5 80 30 E8 D0 B0 F5 80 30 E8 D0 B0 F5 80 30
    E8 D0 BD F9 18 00 18 B9 05 98 6A 49 08 60 99 E0
    BD F9 18 00 40 0B 05 D3 BD F9 18 00 40 F4 70 40
    AD F8 18 00 6B 48 00 78 30 B1 6B 48 00 68 03 90
    6A 48 00 68 04 90 05 E0 69 48 00 68 03 90 69 48
    00 68 04 90 04 98 DD ED 03 0A C0 F5 40 70 00 EE
    10 0A B8 EE C0 1A B7 EE 00 0A 01 EE 20 0A DD ED
    03 0A BD F9 18 00 01 EE 10 0A F2 EE 00 1A B8 EE
    C1 1A 20 EE 21 0A 61 EE 20 0A 80 EE 80 0A 05 98
    00 EE 90 0A B7 EE 00 1A F8 EE 60 0A 31 EE 40 0A
    80 EE 80 0A BC EE C0 0A 46 49 10 EE 10 0A 08 60
    50 E0 9D F8 08 20 49 48 42 49 B0 FB F2 F0 08 60
    48 E0 4D 48 00 78 58 B3 3B 49 46 F6 5A 10 08 60
    3A 49 08 68 40 F0 02 00 08 60 37 49 01 20 08 60
    45 48 00 78 A0 B1 36 48 00 78 40 B1 9D F8 08 00
    34 49 4F F4 FA 32 B2 FB F0 F0 08 60 2A E0 9D F8
    08 00 30 49 4F F4 FA 42 B2 FB F0 F0 08 60 21 E0
    9D F8 08 20 32 48 2B 49 B0 FB F2 F0 08 60 19 E0
    9D F8 08 20 2E 48 27 49 B0 FB F2 F0 08 60 11 E0
    00 98 00 28 3F F4 E9 AE 40 1E 3F F4 1F AF 40 1E
    3F F4 25 AF 40 1E 3F F4 37 AF 40 1E B1 D0 40 1E
    B7 D0 FF E7 08 B0 70 47 28 49 08 68 40 F4 70 00
    08 60 27 49 4F F4 B5 40 08 80 26 49 80 20 08 60
    11 49 46 F6 5A 10 08 60 13 49 4F F4 80 30 08 60
    0B 48 0B 49 00 68 20 F0 07 10 40 F0 03 00 08 60
    09 49 00 20 08 60 1C 48 1B 49 00 68 20 F0 30 00
    08 60 1A 48 19 49 00 68 20 F0 30 00 08 60 70 47
    08 04 01 40 00 89 20 42 00 04 01 40 50 04 01 40
    3C 86 20 42 18 00 00 20 04 04 01 40 60 E3 16 00
    C0 C6 2D 00 80 8D 5B 00 00 1B B7 00 00 36 6E 01
    00 6C DC 02 D8 80 20 42 84 10 20 00 6C 10 20 00
    64 10 20 00 4C 10 20 00 04 89 20 42 88 ED 00 E0
    0C 48 00 40 14 30 04 E0 10 10 01 40 14 10 01 40
    00 2A 4A D0 5F EA 00 0C 8B 07 1C D1 83 07 22 D1
    10 2A 08 D3 70 B4 10 3A 78 C9 78 C0 10 3A FB D2
    70 BC 10 32 38 D0 04 2A 2C D3 08 2A 05 D3 0C 2A
    24 BF 08 C9 08 C0 08 C9 08 C0 08 C9 08 C0 92 07
    2A D0 92 0F 22 E0 0B 78 03 70 49 1C 40 1C 52 1E
    22 D0 8B 07 F7 D1 C3 07 14 D1 83 07 D8 D0 12 1F
    12 D3 08 C9 03 80 1B 0C 43 80 00 1D 12 1F F8 D2
    0A E0 08 C9 03 70 1B 0A 43 70 1B 0A 83 70 1B 0A
    C3 70 00 1D 12 1F F4 D2 12 1D 05 D0 0B 78 03 70
    49 1C 40 1C 52 1E F9 D1 60 46 70 47 00 22 13 46
    0A 46 19 46 71 B5 10 F0 03 0F 0B D0 00 2A 82 BF
    00 F8 01 1B B2 F1 01 02 10 F0 03 0F F6 D1 00 2A
    08 BF 71 BD 11 F0 FF 01 41 EA 01 21 04 2A 18 D3
    41 EA 01 41 08 2A 0F D3 0E 46 10 2A 08 D3 0C 46
    0D 46 B2 F1 0F 03 12 F0 0F 02 72 C0 10 3B FC D8
    12 F0 08 0F 18 BF 42 C0 12 F0 04 0F 18 BF 40 F8
    04 1B 12 F0 02 0F 18 BF 20 F8 02 1B 12 F0 01 0F
    18 BF 01 70 71 BD 70 47 14 48 B0 B5 B0 F1 FF 3F
    01 D0 00 F0 BB F8 12 4D 12 48 A8 42 10 D0 12 48
    12 4C A0 42 0C D0 00 1B 08 3C C7 10 54 F8 08 0F
    01 78 55 F8 21 20 61 68 40 1C 90 47 7F 1E F5 D1
    00 F0 4F F8 0A 4D 0B 4C A5 42 05 D0 02 E0 54 F8
    04 0B 80 47 A5 42 FA D1 B0 BD C0 46 FF FF FF FF
    B4 07 00 00 BC 07 00 00 C4 07 00 00 BC 07 00 00
    00 00 00 00 00 00 00 00 2D E9 F0 41 05 46 15 F8
    01 7B 90 46 0E 46 1C E0 B8 F1 00 0F 05 F1 01 05
    0B D0 FF 2C 09 D8 02 20 15 F8 01 1B 40 1E 41 EA
    04 24 F9 D1 01 E0 04 2C 02 D3 15 F8 01 1B 00 E0
    39 46 30 46 22 46 FF F7 6D FF A6 19 01 E0 06 F8
    01 0B 15 F8 01 0B 87 42 F9 D1 15 F8 01 4B 00 2C
    E9 D1 15 F8 01 0B 2C 78 00 02 24 18 D4 D1 BD E8
    F0 81 70 47 4E F6 88 51 CE F2 00 01 08 68 4F F0
    F0 03 40 EA 03 40 08 60 0C 48 85 46 0C 48 85 44
    6F 46 07 20 87 43 BD 46 0A 48 6F 46 07 60 FF F7
    7A FF 00 F0 AC F8 00 28 01 D0 FF F7 75 FF 00 F0
    7F F8 01 20 00 F0 0E F8 FE E7 C0 46 00 FE 00 20
    00 02 00 00 14 00 00 20 00 BF 70 47 08 B5 FF F7
    FB FF FE E7 38 B5 0D 4C 05 46 A0 68 20 B1 0C 48
    B0 F1 FF 3F 00 D0 80 47 0A 48 00 68 80 47 60 68
    10 B1 01 46 28 46 88 47 20 68 00 B1 80 47 06 48
    00 68 80 47 FF F7 E2 FF 38 BD C0 46 00 00 00 20
    FF FF FF FF 0C 00 00 20 10 00 00 20 F8 B5 06 46
    0F 4D 10 4F 73 88 00 24 17 E0 A0 00 00 EB C4 00
    32 18 51 68 90 68 D2 68 52 B9 AF 42 0B D0 0A 78
    55 F8 22 20 03 46 49 1C 08 46 19 46 90 47 01 E0
    FF F7 96 FE 73 88 64 1C A4 B2 A3 42 E5 DC F8 BD
    B4 07 00 00 BC 07 00 00 AD F1 08 0D 0D 49 4F F4
    B5 40 08 80 0C 49 08 78 40 F0 01 00 08 70 0B 49
    08 78 80 F0 01 00 08 70 42 F2 10 70 00 90 00 98
    00 28 F4 D0 00 98 40 1E 00 90 00 98 00 28 F9 D1
    ED E7 C0 46 0C 48 00 40 04 4C 00 40 02 4C 00 40
    04 49 B1 F1 FF 3F 07 BF 00 21 08 1C 08 68 09 1D
    FF F7 D2 BF FF FF FF FF 03 49 08 60 70 47 02 49
    09 1F 08 60 70 47 70 47 10 00 00 20 D0 F8 03 20
    C3 1D 08 46 19 46 FF F7 4B BE 08 B5 FF F7 EC FD
    FF F7 40 BF 08 BD FE E7 01 22 FF F7 05 BF 01 20
    70 47 FF FF FF FF FF FF 00 02 02 08 00 01 00 00
    00 67 07 00 00 67 07 02 06 00 C0 C6 2D 00 02 00
    00 00 00 00 89 07 00 00 6D 07 00 00 98 07 00 00
    00 00 00 20 FF FF FF FF FF FF FF FF FF FF FF FF
    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    q
    Hi
  • I would recommend trying a factory reset.
    e2e.ti.com/.../1735054
