Part Number: MSP430FR2033
Other Parts Discussed in Thread: MSP430F1121A
Could you please advise an external circuit that satisfies:
- minimum current consumption for blank part. (The FRAM contents are not programmed after ship from TI.)
- 4-wire JTAG terminals are available for CCS to debug-run.
We would like to be concentrated on the external circuit for 4-wire JTAG pins.
I would think the solution would be a resistor (like 1M_ohms) for each JTAG pins, {TCK,TMS,TDI,TDO}. Do you agree?
Background:
My customer board will be assembled with a battery and spend a pretty long time before programming.
Therefore our point is the power consumption with the blank part.
UG slau445g tells that {TCK,TMS,TDI,TDO} should be opened for 4-wire JTAG. (see 1.6 Connection of Unused Pins.)
On the other hand, accorgding to customer tests, {TCK,TMS,TDI} needed to be pulled-down to get LPM4 low current.
Then we thought that:
- It would be necessary to pull-up or pull-down JTAG signals {TCK,TMS,TDI} to minimize the current consumption with a blank parts.
- No idea for TDO. Could you please advise also?
- The pull-up/-down resistor value should be larger enough to accept JTAG connections.
Thank you.
