What is the difference between a Callback function and an Interrupt Handler? When should I write what?
hello Amit,
Following is my code.
/**************************DOCUMENTATION*******************************/
/**********************USB CODE*****************************************/
/*Author PRACHI JOSHI*****/
/****DATE:17/12/2014********/
/* main.c
//TM4C123GH6PMI USB Host functionality
// Basic configuration as a host- mass storage programming example
//The following code shows the basic setup code needed for any application that is using the USB library in host mode.
//The g_pui8HCDPool array which is passed to the USBHCDInit( ) is used as a heap memory for by the USB library and
//thus should not be used by the application. In this example, the g_ppsHostClassDrivers array holds the MSC (mass storage class)
//drivers. The macros provided in the pin_map.h file included with DriverLib can be used to indicate which pin and peripheral
//to use for a given part. The USBHCDRegisterDrivers( ) call passes in the static array of supported USB host class drivers that
//are supported by the application. Typically, the reading or writing to a device is left to a file system layer or through direct
//read and write calls.
#include "inc/tm4c123gh6pm.h"
#include <stdint.h>
#include <stdbool.h>
#include "driverlib/gpio.h"
#include "inc/hw_gpio.h"
#include "driverlib/sysctl.h"
#include "inc/hw_sysctl.h"
#include "inc/hw_types.h"
#include "inc/hw_memmap.h"
#include "driverlib/debug.h"
#include "driverlib/rom.h"
#include "driverlib/pin_map.h"
//extras
//#include "driverlib/fpu.h"
//#include "driverlib/interrupt.h"
//#include <string.h>
#include "driverlib/systick.h"
#include "driverlib/udma.h"
//#include "packages/xdc/std.h"
//#include "packages/xdc/runtime/System.h"
#include "driverlib/usb.h"
#include "inc/hw_usb.h"
#include "usblib/host/usbhost.h" //contains host mode function prototypes and data types
#include "usblib/host/usbhmsc.h" //contains Mass Storage Class definitions specific to hosts
#include "usblib/usblib.h"
#include "usblib/usbmsc.h"
// USB MSD control
#define MSD_NOT_CONNECTED 0
#define MSD_INIT 1
#define MSD_CONNECTED 2
uint32_t iMSDState= MSD_NOT_CONNECTED; //initial value 0
// The number of SysTick ticks per second
#define TICKS_PER_SECOND 100
#define MS_PER_SYSTICK (1000 / TICKS_PER_SECOND)
// A counter for system clock ticks, used for simple timing.
static uint32_t g_ui32SysTickCount;
// Defines the number of times to call to check if the attached device is
// ready.
#define USBMSC_DRIVE_RETRY 4
// Hold the current state for the application.
typedef enum
// No device is present.
STATE_NO_DEVICE,
// Mass storage device is being enumerated.
STATE_DEVICE_ENUM,
// Mass storage device is ready.
STATE_DEVICE_READY,
// An unsupported device has been attached.
STATE_UNKNOWN_DEVICE,
// A mass storage device was connected but failed to ever report ready.
STATE_TIMEOUT_DEVICE,
// A power fault has occurred.
STATE_POWER_FAULT
tState;
volatile tState g_eState;
//volatile tState g_eUIState;
void * g_psDMAControlTable;
extern uint32_t ui32Event;
uint32_t g_ui32UnknownClass; // class of the unknown device
#define HCD_MEMORY_SIZE 128 //the size of the host controller’s memory size in bytes
unsigned char g_pui8HCDPool [HCD_MEMORY_SIZE]; //the memory pool to provide to the host controller driver
// The instance data for the MSC driver.
tUSBHMSCInstance *g_psMSCInstance = 0;
//Declare the USB events driver interface
DECLARE_EVENT_DRIVER(g_sUSBEventDriver, 0, 0, USBHCDEvents);
static tUSBHostClassDriver const * const g_ppsHostClassDrivers[] =
&g_sUSBHostMSCClassDriver,
&g_sUSBEventDriver // why do we add this?
// the global that holds all of the host drivers in use in the application
static const unsigned long g_ui32NumHostClassDrivers = sizeof ( g_ppsHostClassDrivers ) / sizeof ( tUSBHostClassDriver * );
//this global holds the number of class drivers in the g_ppsHostClassDrivers list
// The control table used by the uDMA controller. This table must be aligned
// to a 1024 byte boundary. In this application uDMA is only used for USB,
// so only the first 6 channels are needed.
#if defined(ewarm)
#pragma data_alignment=1024
tDMAControlTable g_sDMAControlTable[6];
#elif defined(ccs)
#pragma DATA_ALIGN(g_sDMAControlTable, 1024)
#else
tDMAControlTable g_sDMAControlTable[6] __attribute__ ((aligned(1024)));
#endif
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
#endif
//This is the handler for the SysTick interrupt. It simply increments a counter that is used for timing.
void
SysTickHandler (void)
g_ui32SysTickCount++;
void USB0HostIntHndler (void)
// glow an LED if the pen drive is detected.
GPIO_PORTF_DATA_R |= 0x16;
//for(ui32Loop = 0; ui32Loop < 200000; ui32Loop++);
GPIO_PORTF_DATA_R &= ~(0x16);
// MSCCallBack
void MSCCallBack (tUSBHMSCInstance *psMSCInstance, uint32_t ui32Event, void *pvEventData)
switch (ui32Event)
// new pen drive detected
case USB_EVENT_CONNECTED:
iMSDState= MSD_INIT;
break;
//pen drive has been unplugged
case USB_EVENT_DISCONNECTED:
break;
// This is the generic callback from host stack.
// \param pvData is actually a pointer to a tEventInfo structure.
// This function will be called to inform the application when a USB event has
// occurred that is outside those related to the mass storage device. At this
// point this is used to detect unsupported devices being inserted and removed.
// It is also used to inform the application when a power fault has occurred.
// This function is required when the g_USBGenericEventDriver is included in
// the host controller driver array that is passed in to the
// USBHCDRegisterDrivers() function.
// \return None.
void
USBHCDEvents(void *pvEventData)
tEventInfo *pEventInfo;
// Cast this pointer to its actual type.
pEventInfo = (tEventInfo *)pvEventData;
switch(pEventInfo->ui32Event)
// Unknown device detected.
case USB_EVENT_UNKNOWN_CONNECTED:
// Save the unknown class.
g_ui32UnknownClass = pEventInfo->ui32Instance;
// An unknown device was detected.
g_eState = STATE_UNKNOWN_DEVICE;
break;
// USB Device has been unplugged.
// Unknown device has been removed.
g_eState = STATE_NO_DEVICE;
break;
case USB_EVENT_POWER_FAULT:
// No power means no device is present.
g_eState = STATE_POWER_FAULT;
break;
default:
break;
//Application Start
void main (void)
uint32_t ui32DriveTimeout;
// Initially wait for device connection.
// Set the clocking to run from the PLL at 50 MHz
SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ);
// enable clocking
SysCtlPeripheralEnable (SYSCTL_PERIPH_USB0);
SysCtlUSBPLLEnable();
//Enable the GPIO peripherals used by the USB pins
SysCtlPeripheralEnable (SYSCTL_PERIPH_GPIOB);
//enable PB0 and PB1 as VBUS and ID pins
GPIOPinTypeUSBAnalog (GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1); // PB0- ID; PB1- VBUS
SysCtlPeripheralEnable (SYSCTL_PERIPH_GPIOD);
// Enable the D+/ D- as USB pins
GPIOPinTypeUSBAnalog (GPIO_PORTD_BASE, GPIO_PIN_4 | GPIO_PIN_5); // PD4- D+, PD5- D-
SysCtlPeripheralEnable (SYSCTL_PERIPH_GPIOC);
// configure USBEPEN as a USB pin
GPIOPinConfigure (GPIO_PC6_USB0EPEN);
GPIOPinTypeUSBDigital (GPIO_PORTC_BASE, GPIO_PIN_6);
//Configure SysTick for a 100 Hz interrupt
SysTickPeriodSet (SysCtlClockGet()/ TICKS_PER_SECOND);
SysTickEnable();
SysTickIntEnable();
//Enable the uDMA controller and set up the control table base
//The uDMA controller is used by the USB library.
SysCtlPeripheralEnable (SYSCTL_PERIPH_UDMA);
uDMAEnable ();
uDMAControlBaseSet (g_psDMAControlTable);
//Initialize the USB stack for host mode
USBStackModeSet(0,eUSBModeHost,0);
// LED initialization
volatile uint32_t ui32Loop;
SYSCTL_RCGC2_R = SYSCTL_RCGC2_GPIOF;
ui32Loop = SYSCTL_RCGC2_R;
GPIO_PORTF_DIR_R = 0xFF;
GPIO_PORTF_DEN_R = 0xFF;
//Register the host class drivers
USBHCDRegisterDrivers (0, g_ppsHostClassDrivers, g_ui32NumHostClassDrivers);
// Initialize the power configuration. Set the power enable signal to be active high and does not enable the power fault.
// USBHCDPowerConfigInit (0, USBHCD_VBUS_AUTO_HIGH | USBHCD_VBUS_FILTER);
// call any open routines here for the application to be ready for a new mass storage device
tUSBHMSCInstance *g_psMSCInstance= USBHMSCDriveOpen (0, MSCCallBack); // open an instance of the mass storage class driver
USBHCDInit (0, g_pui8HCDPool, HCD_MEMORY_SIZE); // initialize the host controller
//LED glow
// main loop of the application
while (1)
switch (iMSDState)
//This state is entered when the pen drive is first detected.
case MSD_INIT:
//initialize the newly connected pen drive
// wait for the drive to become ready- wait for the value to go to 0 before the host controller attempts to read or write from the device.
while ( USBHMSCDriveReady (g_psMSCInstance))
SysCtlDelay(SysCtlClockGet( ) / 3); //delay given for the device to be ready
ui32DriveTimeout--;
// If the timeout is hit then go to the
// STATE_TIMEOUT_DEVICE state.
if(ui32DriveTimeout == 0)
g_eState = STATE_TIMEOUT_DEVICE;
//move it to connected state
iMSDState= MSD_CONNECTED;
break;
case MSD_CONNECTED:
break;
case MSD_NOT_CONNECTED:
// glow an LED if no device is connected.
GPIO_PORTF_DATA_R |= 0x04;
GPIO_PORTF_DATA_R &= ~(0x04);
break;
default:
break;
USBHCDMain( ); // Periodic call for the Host Controller Drivers
I checked it by stepwise debugging. The program control is not going to the call back function.
Please guide me.
