Other Parts Discussed in Thread: LMFLASHPROGRAMMER, EK-TM4C123GXL
for a new project, we are planning to use the TM4C1290 microcontroller. For the development and the debugging of application code, we will use the uvision 4 IDE and the ulink 2 as USB to JTAG debugger both from KEIL. I have a question about the recovering sequence described in the datasheet (document SPMS429B) chapter 4.3.4.3, page 207.
Is there any way to recover a locked microcontroller using the IDE and the debugger above indicated? Can you please explain me the sequence to be done?
We will do the same question also to KEIL support service but, maybe, you already know the answer.
My request comes from mass production needs. If, for any reason, the microcontroller gets locked at the end of line, I need the possibility to recover the part; on the board, there is the JTAG connector.
If, with our tools, is not possible to recover the part, do you know if there are some other tools (maybe from texas instruments) to recover the microcontroller throug the jtag connector?
Tank you. Best regards.
Daniele
