Hi, I'll hope you can help me with this problem.
I've added the "utils/uartstdio.c" to the workspace and also I tested the example code "hello" and works.
If I use UARTConfigSetExpClk i cand send characteres.
Here is my code:
#define RED_LED GPIO_PIN_1 #define BLUE_LED GPIO_PIN_2 #define GREEN_LED GPIO_PIN_3 #define SW1 GPIO_PIN_4 #define SW2 GPIO_PIN_0 // Variables para el control, directo, del angulo. #define minAlpha 9000 // #define maxAlpha 590000 // La diferencia es de 581000 uint32_t alpha = maxAlpha; // Nos aseguramos que el motor inicie lento. // Variables para usar con QEI uint8_t QEI_fs = 0x01; // Tiempo de captura en el QEI (1/QEI_fs) float rpm = 0; // Variables auxiliares para leds uint8_t state = 0x00; // Variable auxiliar para usar en el led verder, QEI uint8_t state2 = 0x02; uint8_t state4 = 0x04; uint32_t V_rpm[20] ; uint32_t V_alpha[20] ; uint8_t count = 0; void config() { SysCtlClockSet(SYSCTL_SYSDIV_2_5|SYSCTL_USE_PLL|SYSCTL_OSC_MAIN|SYSCTL_XTAL_16MHZ); ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); // Reloj del puerto F, Led's e interruptores ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD); // Reloj del puerto D, QEI ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); // Configuracion del puerto UART ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); ROM_GPIOPinConfigure(GPIO_PA0_U0RX); ROM_GPIOPinConfigure(GPIO_PA1_U0TX); ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); // Configure the pins for the receiver and transmitter using GPIOPinConfigure //UARTConfigSetExpClk(UART0_BASE, SysCtlClockGet(), 115200,(UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE | UART_CONFIG_PAR_NONE)); // Initialize the parameters for the UART: 115200, 8-1-N UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC); // // Initialize the UART for console I/O. // UARTStdioConfig(0, 115200, 16000000); // UARTStdioConfig(0, 115200, 16000000); // Configuracion del puerto digital GPIOF // Se desbloquea el GPIOF_0, para poder ocupar SW2 HWREG(GPIO_PORTF_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY; HWREG(GPIO_PORTF_BASE + GPIO_O_CR) |= 0x01; HWREG(GPIO_PORTF_BASE + GPIO_O_LOCK) = 0; GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED); ROM_GPIOPinTypeGPIOInput(GPIO_PORTF_BASE, SW1 | SW2); // Se declara pin de entrada, SW1 y SW2 //ROM_GPIOPadConfigSet(GPIO_PORTF_BASE, SW1 , GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD_WPU); // Se configura la resistencia pull-up PF_4 ROM_GPIOPadConfigSet(GPIO_PORTF_BASE, SW2 , GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD_WPU); // Se configura la resistencia pull-up PF_0 // CONFIGURACIONES DEL QEI // Se desbloquea le pin GPIOD7, para usarlo con el QEI HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY; HWREG(GPIO_PORTD_BASE + GPIO_O_CR) |= 0x80; HWREG(GPIO_PORTD_BASE + GPIO_O_AFSEL) &= ~0x80; HWREG(GPIO_PORTD_BASE + GPIO_O_DEN) |= 0x80; HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = 0; SysCtlPeripheralEnable(SYSCTL_PERIPH_QEI0); // Se habilita el periferioco QEI GPIOPinConfigure(GPIO_PD6_PHA0); // Pin GPIOD6 como PHA0 // GPIOPinConfigure(0x00031806); //0x00031806 =>GPIO_PD6_PHA0 GPIOPinTypeQEI(GPIO_PORTD_BASE, GPIO_PIN_6); // Pin GPIOD6 como PHA0 QEIConfigure(QEI0_BASE,(QEI_CONFIG_CAPTURE_A | QEI_CONFIG_NO_RESET | QEI_CONFIG_CLOCK_DIR | QEI_CONFIG_NO_SWAP), 1725); // Configuracion del enconder de cuadratura QEIVelocityConfigure(QEI0_BASE, QEI_VELDIV_2, (SysCtlClockGet()/QEI_fs)); // Divide by clock speed to get counts/sec QEIVelocityEnable(QEI0_BASE); // QEI velocidad activada // CONFIGURACIONES DEL TIMER SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0); TimerConfigure(TIMER0_BASE, TIMER_CFG_ONE_SHOT); TimerLoadSet(TIMER0_BASE, TIMER_A, minAlpha + alpha); // CONFIGURACION DE INTERRUPCIONES IntPrioritySet(INT_TIMER0A, 0x20); // Prioridad 1, del TIMER0 IntEnable(INT_TIMER0A); TimerIntEnable(TIMER0_BASE, TIMER_TIMA_TIMEOUT); // Interrupcion TIMER0, activada IntPrioritySet(INT_QEI0, 0x04); // Prioridad 2, de la interrupcion QEI IntEnable(INT_QEI0); // Habilitada interrupcion de QEI QEIIntEnable(QEI0_BASE,QEI_INTTIMER); // Habilitada la interrupcion QEI IntPrioritySet(GPIO_PORTF_BASE,0x00); // Prioridad 0, para el cruce por cero. IntEnable(INT_GPIOF); // Habilitada la interrupcion GPIOF PF_4 GPIOIntEnable(GPIO_PORTF_BASE, GPIO_INT_PIN_4); // Habilitada en el pin 4, SW1 //Erase a block of the flash. // FlashErase(0x1000); // // Program some data into the newly erased block of the flash. // //pui32Data[0] = 0; IntMasterEnable(); // ACTIVACION DE PERIFERICOS TimerEnable(TIMER0_BASE, TIMER_A); QEIEnable(QEI0_BASE); } void main(void){ config(); while(1){ if(alpha <= 357600){ FlashProgram(V_rpm, 0x1000, sizeof(V_rpm)); FlashProgram(V_alpha,0x106C,sizeof(V_alpha)); while(1); } } } // Envia el pulso para controlar los SCR's void Timer0IntHandler(void){ TimerIntClear(TIMER0_BASE, TIMER_TIMA_TIMEOUT); // Clear the timer interrupt IntMasterDisable(); // Se deshabilitan las interrupciones GPIOPinWrite(GPIO_PORTF_BASE, RED_LED, 0x02); ROM_SysCtlDelay(5333); // (3 ciclos de reloj)(12.5ns)(5333) ~ 200us GPIOPinWrite(GPIO_PORTF_BASE, RED_LED, 0x00); IntMasterEnable(); // Habilitamos las interrupciones } // Obtiene la velocidad del encoder void QEI0IntHandler(void){ float velocidad; QEIIntClear(QEI0_BASE,QEI_INTTIMER); //GPIOPinWrite(GPIO_PORTF_BASE, GREEN_LED, state); state = ~ state; velocidad = QEIVelocityGet(QEI0_BASE); rpm = (velocidad/1024)*60*QEI_fs; // Calculo de las revoluciones if (alpha > 357600){ alpha -= 11620; V_rpm[count] =(uint32_t) rpm; V_alpha[count] = alpha; count ++; } } // Detecta el cruce por cero y manda el angulo para controlar la velocidad void GPIOFIntHandler(void){ GPIOIntClear(GPIO_PORTF_BASE, GPIO_INT_PIN_4); //GPIOPinWrite(GPIO_PORTF_BASE, BLUE_LED, state4); state4 = ~state4; TimerLoadSet(TIMER0_BASE, TIMER_A, minAlpha + alpha); TimerEnable(TIMER0_BASE, TIMER_A); }
