Application Note Release: Using TM4C12x Devices Over JTAG Interface
Hello TM4C Forum,
The Application Note for Using TM4C12x Devices Over JTAG Interface has been released on TM4C web page.
As usual, feedback is much appreciated.
Amit
  • Greetings Amit,
    Overall good - yet may these 3 suggestions (even) improve:
    • i-jet's inclusion over the FAR more popular J-Link (for IAR) seems "unusual."
    • as so many here suffer from "Lockout" might "recovery" receive greater highlight & instruction - especially "Lockout avoidance" tactics!
    • and always - external, properly sized pull-up resistors should be employed - NOT the far too high valued internal (MCU) ones.
  • Hello cb1
    Thanks a lot:
    1. We have access to J-Link probes only. I will see if I can add i-Jet in the next revision of the document
    2. Section 5.1 and 5.2 warn users on Lockout.... May be a strong Caution/Note would make the highlight....
    Amit
  • Hi Amit,
    That's bit unclear - my read/review of your neat App Note revealed i-Jet ONLY - not the (FAR) more popular J-Link.
    J-Link - I believe - should be included w/in your note.
    And again - as JTAG Lockout occurs so often here - STRONG Warnings/CAUTIONS against all "Usual Suspect" causes - should receive EARLY and REPEATED (i.e. well highlighted) emphasis...   (failing to properly highlight is like driving a winding mountain trail - w/guard-rails removed!)
  • Hello cb1
    That was a typo "Friday factor". I meant
    We have access to i-Jet probes only. I will see if I can add J-Link (provided I can trace one of those probes locally) in the next revision of the document
    Amit
  • Recall that Segger offers J-Link probes (which manage both JTAG & SWD) at GREAT, Educational discount - even to (and especially to) Non-Students! J-Link is the pre-dominant JTAG probe - to firm's & my mind - far outperforms the (lesser) probes - which may just ADD to the dreaded JTAG-Lockout - again so often (surely every 2-3 days) reported here!
  • Hello cb1
    Point noted.... :-). And a usual a great many thanks to point out the missing/critical features to highlight.
    Amit
