Part Number: TM4C123GH6PGE
Tool/software: Starterware
Hello all,
After wasting too much time on trying to make a wide timer work in split pair using common sense, documentation and this forum's much appreciated examples, I finally found the problem:
driverlib/timer.c , line360, function TimerConfigure, in the second ASSERT
ASSERT(((ui32Config & 0xff000000) != TIMER_CFG_SPLIT_PAIR) ||
This renders any attempt at configuring for split pair, totally useless. It ignores it.
Instead, modify this line to:
ASSERT(((ui32Config & 0xff000000) == TIMER_CFG_SPLIT_PAIR) ||
Please fix this in Tivaware if not already fixed (haven't checked).
All the best,
The guy that did not want to post from his normal Ti account because of the stupid way his name was changed and can't be fixed.
