hi could you tell me typical logic input threshold level? customer want to use this with VHYS spec.
Hello Ito-san,
Thank you for posting to the MD forum. Typical values for logic level inputs are not usually defined in datasheets, what the datasheet does is define what voltages are considered high and low. If the voltage is 0.7 and below the logic level input will be considered low. If the voltage is 1.6 or above then it will be considered high.
I hope this helps!
Isaac
