Hi team,
Could you kindly help me attached questions? Thanks!
IC(DRV2511QDAPRQ1)问题点询问-20220118.xlsx
Jiawei
Hi team,
Jiawei
Hi Jiawei,
Thank you for your questions. Please give me a day or two to go through your questions and get the best answer for you.
Christine
Hi Christine,
Could you kindly give feedback by tomorrow? Customer are urgent for this. Thanks!
Jiawei
Hi Jiawei,
From the question in the attached document:
1. As long as you aren't trying to surpass a current of 4.7A, these inductors chosen should be fine. This post might also help with more information on this.
2. If you are setting the PWM signal to 0, the current would be driven to ground. Are you expecting a reverse current here?
3. They should not increase as mentioned so this should not be a problem. The supplies should be stable with the capacitor choices that are shown in the design.
4. The function of the LPF circuit is to transform the PWM signal into a sine wave which the input pin can take. As a reminder, this is an analog input.
Christine
Hi Christine,
Thanks for your reply. I have another questions:
for Single end input, datasheet have following describe:
that means IN- have following three connect options or just have ① and ③ , what is different?
① IN-pull up to 3V;
② IN-tied to GND;
③ IN- 0.1uF to GND
BR
Jiawei
Hi Jiawei,
Please give me until the end of the week to respond.
Christine
Hi Jiawei,
It looks like the answers to these questions are already being answered here. Please look at this E2E thread for guidance.
Christine
