Hi team,
Here's an issue from the customer may need your help:
How to connect the three Hall sensors of DRV8306? The customer chose a three-pin hall sensor, how should they connect it? Or is the three-pin Hall sensor not acceptable? To use a hall sensor with four pins? If so, what is the recommended model for a four pin hall sensor? How to connect?
Could you help check this case? Thanks.
Cherry
