Other Parts Discussed in Thread: MCF8316A
Hi team,
Here's an issue from the customer may need your help:
The evaluation board does not work.
After power-on, the GUI communication status is normal and the D6 cycle blinks. Read and write EEPROM or motor parameters, using E2PROM as an example, a red prompt box pops up in the lower left corner of the GUI:! Inital Read failed X
The prompt box then changes to the “Hardware not Connected" and a dialog box pops up in the middle of the GUI: "Connectivity issue There is an issue with the device connectivity. Please restart the GUI. OKAY"
The problem persists after restarting the GUI. Could you help check this case? Thanks.
Cherry
