Hi team,
Here's an issue from the customer may need your help:
Customer has a 60*40 motor array to drive. The available schemes are as follows: DRV8912 can output 12 and combine the outputs using daisy chain mode. But the combination requires too many chips. Could you help recommend chips that integrate more drives?
Could you help check this case? Thanks.
Cherry
