Hi Expert,
One question for IC_CTRL and BRG_CTRL. My customer is using DRV8705-Q1 SPI version in their new project.
I would like to check with you if we can config like this in PH/EN mode, PWM input from MCU to IN1/EN of DRV8705-Q1, but IN2/PH is controlled by register. Because customer do not connect IN2/PH to MCU pin.
If yes, how to config? Set IN2/PH_MODE bit to 1 in IC_CTRL register, and control the signal by S_IN2/PH bit in BRG_CTRL register?
Thanks!
Ethan Wen
