Hi Team,
1) According to the documentation, neither PWM mode nor stand-alone mode is supported. However, it is on at LVL1 of demo board mode1 and the LVL2LVL3 has no effect with the jumper attached. The customer would like to make sure if the drive only support LVL1.
2) Unable to enter sleep mode. Is it possible to go to sleep mode by pulling Nsleep low in standby mode as described in the document? Or could you help tell what is the instruction to enter sleep mode correctly?
3) Cannot enter the Hi-Z state. In both cases of Hi-Z, using the same high and low control, the result is always low.
Could you help check this case? Thanks.
Cherry
