Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
DRV2667: Power consumption on 500Hz_180Vpp_10nF output
Part Number: DRV2667
Hi Team,
Do you know what is the power consumption when DRV2667 load 10nF and output 500Hz 180Vpp?It is not on the datasheet. The customer requiring 150mW with 4.2V battery voltage.
Peter Wei
  • Hi Peter,
    I did not have the proper load to manually test this, but am able to provide some calculations. Essentially, the load needs more current than what the customer battery requirements can provide.
    Hope this helps!
    Sydney Northcutt
