Part Number: MCT8329EVM
Other Parts Discussed in Thread: MCT8329A
We use MCT8329EVM to drive an eBike BLDC motor.
The motor specification is: 36V, max 580W. no loading.
We try to startup motor by align, double align, IPD and slow first.
Only slow first can work. All other methods are fail.
However, we turn the parameters and set various duty cycle as below:
eBike motor 36V batt. |
duty % |
10 |
20 |
30 |
40 |
50 |
60 |
70 |
ISD_CONFIG |
(0x0080) |
0x7F404D06 |
0x7F404D06 |
0x7F404D06 |
0x7F404D06 |
0x7F404D06 |
0x7F404D06 |
0x7F404D06 |
MOTOR_STARTUP1 |
(0x0082) |
0x6C9265B8 |
0x6C9265B8 |
0x6C9265B8 |
0x6C9265B8 |
0x6C9265B8 |
0x6C9265B8 |
0x6C9265B8 |
MOTOR_STARTUP2 |
(0x0084) |
0x5A18B295 |
0x5A18B295 |
0x5A18B295 |
0x5A18B295 |
0x5A18B295 |
0x5A18B295 |
0x5A18B295 |
CLOSED_LOOP1 |
(0x0086) |
0x1025E600 |
0x1025E600 |
0x1025E600 |
0x1025E600 |
0x1025E600 |
0x1025E600 |
0x1025E600 |
CLOSED_LOOP2 |
(0x0088) |
0x02A1A428 |
0x02A1A428 |
0x02A1A428 |
0x02A1A428 |
0x02A1A428 |
0x02A1A428 |
0x02A1A428 |
CLOSED_LOOP3 |
(0x008A) |
0x34C92001 |
0x34C92001 |
0x34C92001 |
0x34C92001 |
0x34C92001 |
0x34C92001 |
0x34C92001 |
CLOSED_LOOP4 |
(0x008C) |
0x001AC953 |
0x001AC953 |
0x001AC953 |
0x001AC953 |
0x001AC953 |
0x001AC953 |
0x001AC953 |
CONST_SPEED |
(0x008E) |
0x30010000 |
0x30010000 |
0x30010000 |
0x30010000 |
0x30010000 |
0x30010000 |
0x30010000 |
CONST_PWR |
(0x0090) |
0x1F400640 |
0x1F400640 |
0x1F400640 |
0x1F400640 |
0x1F400640 |
0x1F400640 |
0x1F400640 |
FAULT_CONFIG1 |
(0x0092) |
0x71783624 |
0x71783624 |
0x71783624 |
0x71783624 |
0x71783624 |
0x71783624 |
0x71783624 |
FAULT_CONFIG2 |
(0x0094) |
0x7C85C00A |
0x7C85C00A |
0x7C85C00A |
0x7C85C00A |
0x7C85C00A |
0x7C85C00A |
0x7C85C00A |
150_DEG_TWO_PH_PROFILE |
(0x0096) |
0x24DB7200 |
0x24DB7200 |
0x24DB7200 |
0x24DB7200 |
0x24DB7200 |
0x24DB7200 |
0x24DB7200 |
150_DEG_THREE_PH_PROFILE |
(0x0098) |
0x48DB6946 |
0x48DB6946 |
0x48DB6946 |
0x48DB6946 |
0x48DB6946 |
0x48DB6946 |
0x48DB6946 |
REF_PROFILES1 |
(0x009A) |
0x032184A6 |
0x032184A6 |
0x032184A6 |
0x032184A6 |
0x032184A6 |
0x032184A6 |
0x032184A6 |
REF_PROFILES2 |
(0x009C) |
0x34C80AFC |
0x34C80AFC |
0x34C80AFC |
0x34C80AFC |
0x34C80AFC |
0x34C80AFC |
0x34C80AFC |
REF_PROFILES3 |
(0x009E) |
0x4787D70C |
0x4787D70C |
0x4787D70C |
0x4787D70C |
0x4787D70C |
0x4787D70C |
0x4787D70C |
REF_PROFILES4 |
(0x00A0) |
0x000C9932 |
0x000C9932 |
0x000C9932 |
0x000C9932 |
0x000C9932 |
0x000C9932 |
0x000C9932 |
REF_PROFILES5 |
(0x00A2) |
0x1F6BF200 |
0x1F6BF200 |
0x1F6BF200 |
0x1F6BF200 |
0x1F6BF200 |
0x1F6BF200 |
0x1F6BF200 |
REF_PROFILES6 |
(0x00A4) |
0x00708000 |
0x00708000 |
0x00708000 |
0x00708000 |
0x00708000 |
0x00708000 |
0x00708000 |
PIN_CONFIG1 |
(0x00A6) |
0x20600002 |
0x20600002 |
0x20600002 |
0x20600002 |
0x20600002 |
0x20600002 |
0x20600002 |
PIN_CONFIG2 |
(0x00A8) |
0x3E0020AA |
0x3E0020AA |
0x3E0020AA |
0x3E0020AA |
0x3E0020AA |
0x3E0020AA |
0x3E0020AA |
DEVICE_CONFIG |
(0x00AA) |
0x27100008 |
0x27100008 |
0x27100008 |
0x27100008 |
0x27100008 |
0x27100008 |
0x27100008 |
GD_CONFIG1 |
(0x00AC) |
0x000200FC |
0x000200FC |
0x000200FC |
0x000200FC |
0x000200FC |
0x000200FC |
0x000200FC |
GD_CONFIG2 |
(0x00AE) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
GATE_DRIVER_FAULT_STATUS |
(0x00E0) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
CONTROLLER_FAULT_STATUS |
(0x00E2) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
SYS_STATUS1 |
(0x00E4) |
0x00EF18F2 |
0x00F53344 |
0x00F54D24 |
0x00F56682 |
0x00F58028 |
0x00F59928 |
0x00F5B3B6 |
ALGO_CTRL1 |
(0x00E6) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
DEVICE_CTRL |
(0x00E8) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
SYS_STATUS2 |
(0x00EA) |
0x20010151 |
0x20010292 |
0x200103E3 |
0x200104DD |
0x20010587 |
0x2001073D |
0x200107B2 |
SYS_STATUS3 |
(0x00EC) |
0xFFFFF829 |
0xFFFFE48E |
0xFFFFD6BE |
0xFFFFC90B |
0xFFFFBC8C |
0xFFFFAD9F |
0xFFFFA548 |
INPUT_DUTY |
(0x040C) |
0x06470000 |
0x0CC78000 |
0x13460000 |
0x19B38000 |
0x200A0000 |
0x264C8000 |
0x2CF20000 |
CURRENT_DUTY |
(0x0512) |
0x067E5138 |
0x0CC78000 |
0x134FB156 |
0x19AB38C3 |
0x200209E0 |
0x267C0000 |
0x2CE9B639 |
SET_DUTY |
(0x0522) |
0x06928000 |
0x0CD90000 |
0x133F8000 |
0x19BA0000 |
0x200A0000 |
0x264A0000 |
0x2CED8000 |
MOTOR_SPEED_PU |
(0x05CE) |
0x02282BB3 |
0x0436AC70 |
0x0661B778 |
0x0860AC63 |
0x0A6FDA3F |
0x0C3BCAF3 |
0x0E2168C3 |
DC_BUS_POWER_PU |
(0x0714) |
0xEB5FC000 |
0xB9618000 |
0x967DC000 |
0x80000000 |
0x80000000 |
0x80000000 |
0x80000000 |
the questions:
1. sometimes the startup process may fail.
2. 0x417 seems be a negative value and it keeps 0x80000000 if duty >40%
3. if we set startup frequency < 40Hz, it will short circuit.
4. 0xEC current is always 0xffff, battery power is wrong value
After that, we try another parameters, the tables show below:
0x90 max_spd=64000, |
PWM duty |
100% |
80% |
60% |
30% |
10% |
ISD_CONFIG |
(0x0080) |
0x7F404D06 |
0x7F404D06 |
0x7F404D06 |
0x7F404D06 |
0x7F404D06 |
MOTOR_STARTUP1 |
(0x0082) |
0x6C9265B8 |
0x6C9265B8 |
0x6C9265B8 |
0x6C9265B8 |
0x6C9265B8 |
MOTOR_STARTUP2 |
(0x0084) |
0x5A18B295 |
0x5A18B295 |
0x5A18B295 |
0x5A18B295 |
0x5A18B295 |
CLOSED_LOOP1 |
(0x0086) |
0x3025E600 |
0x3025E600 |
0x3025E600 |
0x3025E600 |
0x3025E600 |
CLOSED_LOOP2 |
(0x0088) |
0x02A1A428 |
0x02A1A428 |
0x02A1A428 |
0x02A1A428 |
0x02A1A428 |
CLOSED_LOOP3 |
(0x008A) |
0x34C92001 |
0x34C92001 |
0x34C92001 |
0x34C92001 |
0x34C92001 |
CLOSED_LOOP4 |
(0x008C) |
0x001AC953 |
0x001AC953 |
0x001AC953 |
0x001AC953 |
0x001AC953 |
CONST_SPEED |
(0x008E) |
0x30010000 |
0x30010000 |
0x30010000 |
0x30010000 |
0x30010000 |
CONST_PWR |
(0x0090) |
0x7D006400 |
0x7D006400 |
0x7D006400 |
0x7D006400 |
0x7D006400 |
FAULT_CONFIG1 |
(0x0092) |
0x71783624 |
0x71783624 |
0x71783624 |
0x71783624 |
0x71783624 |
FAULT_CONFIG2 |
(0x0094) |
0x7C85C00A |
0x7C85C00A |
0x7C85C00A |
0x7C85C00A |
0x7C85C00A |
(0x0096) |
0x24DB7200 |
0x24DB7200 |
0x24DB7200 |
0x24DB7200 |
0x24DB7200 |
(0x0098) |
0x48DB6946 |
0x48DB6946 |
0x48DB6946 |
0x48DB6946 |
0x48DB6946 |
REF_PROFILES1 |
(0x009A) |
0x032184A6 |
0x032184A6 |
0x032184A6 |
0x032184A6 |
0x032184A6 |
REF_PROFILES2 |
(0x009C) |
0x34C80AFC |
0x34C80AFC |
0x34C80AFC |
0x34C80AFC |
0x34C80AFC |
REF_PROFILES3 |
(0x009E) |
0x4787D70C |
0x4787D70C |
0x4787D70C |
0x4787D70C |
0x4787D70C |
REF_PROFILES4 |
(0x00A0) |
0x000C9932 |
0x000C9932 |
0x000C9932 |
0x000C9932 |
0x000C9932 |
REF_PROFILES5 |
(0x00A2) |
0x1F6BF200 |
0x1F6BF200 |
0x1F6BF200 |
0x1F6BF200 |
0x1F6BF200 |
REF_PROFILES6 |
(0x00A4) |
0x00708000 |
0x00708000 |
0x00708000 |
0x00708000 |
0x00708000 |
PIN_CONFIG1 |
(0x00A6) |
0x20600002 |
0x20600002 |
0x20600002 |
0x20600002 |
0x20600002 |
PIN_CONFIG2 |
(0x00A8) |
0x3E0020AA |
0x3E0020AA |
0x3E0020AA |
0x3E0020AA |
0x3E0020AA |
DEVICE_CONFIG |
(0x00AA) |
0x27100008 |
0x27100008 |
0x27100008 |
0x27100008 |
0x27100008 |
GD_CONFIG1 |
(0x00AC) |
0x000200FC |
0x000200FC |
0x000200FC |
0x000200FC |
0x000200FC |
GD_CONFIG2 |
(0x00AE) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
(0x00E0) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
(0x00E2) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
SYS_STATUS1 |
(0x00E4) |
0x00F2FFFE |
0x00F3CD0E |
0x00F69920 |
0x00F34D18 |
0x00ED19B8 |
ALGO_CTRL1 |
(0x00E6) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
DEVICE_CTRL |
(0x00E8) |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
0x00000000 |
SYS_STATUS2 |
(0x00EA) |
0x20010BCB |
0x200109A1 |
0x20010751 |
0x200103AF |
0x20010140 |
SYS_STATUS3 |
(0x00EC) |
0xFFFF78C9 |
0xFFFF931A |
0xFFFFAD43 |
0xFFFFD742 |
0xFFFFF8A1 |
INPUT_DUTY |
(0x040C) |
0x3FFF8000 |
0x333F0000 |
0x26738000 |
0x13360000 |
0x06740000 |
CURRENT_DUTY |
(0x0512) |
0x3FFF8000 |
0x333ED4B2 |
0x2677538B |
0x133F0000 |
0x0677B608 |
SET_DUTY |
(0x0522) |
0x3FFF8000 |
0x33320000 |
0x26738000 |
0x13360000 |
0x06488000 |
MOTOR_SPEED_PU |
(0x05CE) |
0x04D95B38 |
0x03EF4EDD |
0x02FFEACE |
0x01811CC1 |
0x00834C1F |
DC_BUS_POWER_PU |
(0x0714) |
0xF0128000 |
0xF3320000 |
0xF66D4000 |
0xFB33C000 |
0xFF204000 |
[motor 100+ok]
[8329_dump+ok]
[517379] ISD_CONFIG (0x0080) = 0x7F404D06
[517383] MOTOR_STARTUP1 (0x0082) = 0x6C9265B8
[517388] MOTOR_STARTUP2 (0x0084) = 0x5A18B295
[517392] CLOSED_LOOP1 (0x0086) = 0x3025E600
[517397] CLOSED_LOOP2 (0x0088) = 0x02A1A428
[517401] CLOSED_LOOP3 (0x008A) = 0x34C92001
[517405] CLOSED_LOOP4 (0x008C) = 0x001AC953
[517410] CONST_SPEED (0x008E) = 0x30010000 KP=768/10000, KI=256/1M, Loop_mode=0 1:spd,2:pwr
[517418] CONST_PWR (0x0090) = 0x7D006400 M_spd=64000, M_pwr=1600
[517424] FAULT_CONFIG1 (0x0092) = 0x71783624
[517429] FAULT_CONFIG2 (0x0094) = 0x7C85C00A
[517433] 150_DEG_TWO_PH_PROFILE (0x0096) = 0x24DB7200
[517438] 150_DEG_THREE_PH_PROFILE (0x0098) = 0x48DB6946
[517444] REF_PROFILES1 (0x009A) = 0x032184A6
[517448] REF_PROFILES2 (0x009C) = 0x34C80AFC
[517453] REF_PROFILES3 (0x009E) = 0x4787D70C
[517457] REF_PROFILES4 (0x00A0) = 0x000C9932
[517462] REF_PROFILES5 (0x00A2) = 0x1F6BF200
[517466] REF_PROFILES6 (0x00A4) = 0x00708000
[517471] PIN_CONFIG1 (0x00A6) = 0x20600002
[517475] PIN_CONFIG2 (0x00A8) = 0x3E0020AA
[517479] DEVICE_CONFIG (0x00AA) = 0x27100008
[517483] GD_CONFIG1 (0x00AC) = 0x000200FC Dir= Uni, CSA=0
[517489] GD_CONFIG2 (0x00AE) = 0x00000000
[517493] GATE_DRIVER_FAULT_STATUS (0x00E0) = 0x00000000
[517498] CONTROLLER_FAULT_STATUS (0x00E2) = 0x00000000
[517503] SYS_STATUS1 (0x00E4) = 0x00F2FFFE Volt_mag=24.200, Motor_Spd(eHz)=100.000%
[517511] ALGO_CTRL1 (0x00E6) = 0x00000000
[517515] DEVICE_CTRL (0x00E8) = 0x00000000
[517519] SYS_STATUS2 (0x00EA) = 0x20010BCB State=0x2, Motor_Spd(eHz)=301.900
[517526] SYS_STATUS3 (0x00EC) = 0xFFFF78C9 (BUS_Curr=0xffff)
[517533] INPUT_DUTY (0x040C) = 0x3FFF8000 In_duty=99.997%
[517539] CURRENT_DUTY (0x0512) = 0x3FFF8000 Curr_duty=99.997%
[517545] SET_DUTY (0x0522) = 0x3FFF8000 Set_duty=99.997%
[517550] MOTOR_SPEED_PU (0x05CE) = 0x04D95B38 Motor_Spd=4849.048
[517556] DC_BUS_POWER_PU (0x0714) = 0xF0128000 Motor_Pwr=6001.807
[motor 80+ok]
[8329_dump+ok]
[529834] ISD_CONFIG (0x0080) = 0x7F404D06
[529838] MOTOR_STARTUP1 (0x0082) = 0x6C9265B8
[529842] MOTOR_STARTUP2 (0x0084) = 0x5A18B295
[529847] CLOSED_LOOP1 (0x0086) = 0x3025E600
[529851] CLOSED_LOOP2 (0x0088) = 0x02A1A428
[529855] CLOSED_LOOP3 (0x008A) = 0x34C92001
[529860] CLOSED_LOOP4 (0x008C) = 0x001AC953
[529864] CONST_SPEED (0x008E) = 0x30010000 KP=768/10000, KI=256/1M, Loop_mode=0 1:spd,2:pwr
[529872] CONST_PWR (0x0090) = 0x7D006400 M_spd=64000, M_pwr=1600
[529878] FAULT_CONFIG1 (0x0092) = 0x71783624
[529883] FAULT_CONFIG2 (0x0094) = 0x7C85C00A
[529887] 150_DEG_TWO_PH_PROFILE (0x0096) = 0x24DB7200
[529892] 150_DEG_THREE_PH_PROFILE (0x0098) = 0x48DB6946
[529898] REF_PROFILES1 (0x009A) = 0x032184A6
[529902] REF_PROFILES2 (0x009C) = 0x34C80AFC
[529907] REF_PROFILES3 (0x009E) = 0x4787D70C
[529911] REF_PROFILES4 (0x00A0) = 0x000C9932
[529916] REF_PROFILES5 (0x00A2) = 0x1F6BF200
[529920] REF_PROFILES6 (0x00A4) = 0x00708000
[529925] PIN_CONFIG1 (0x00A6) = 0x20600002
[529929] PIN_CONFIG2 (0x00A8) = 0x3E0020AA
[529933] DEVICE_CONFIG (0x00AA) = 0x27100008
[529937] GD_CONFIG1 (0x00AC) = 0x000200FC Dir= Uni, CSA=0
[529943] GD_CONFIG2 (0x00AE) = 0x00000000
[529947] GATE_DRIVER_FAULT_STATUS (0x00E0) = 0x00000000
[529952] CONTROLLER_FAULT_STATUS (0x00E2) = 0x00000000
[529957] SYS_STATUS1 (0x00E4) = 0x00F3CD0E Volt_mag=24.300, Motor_Spd(eHz)=80.102%
[529965] ALGO_CTRL1 (0x00E6) = 0x00000000
[529969] DEVICE_CTRL (0x00E8) = 0x00000000
[529973] SYS_STATUS2 (0x00EA) = 0x200109A1 State=0x2, Motor_Spd(eHz)=246.500
[529980] SYS_STATUS3 (0x00EC) = 0xFFFF931A
[529987] INPUT_DUTY (0x040C) = 0x333F0000 In_duty=80.072%
[529993] CURRENT_DUTY (0x0512) = 0x333ED4B2 Curr_duty=80.071%
[529999] SET_DUTY (0x0522) = 0x33320000 Set_duty=79.993%
[530004] MOTOR_SPEED_PU (0x05CE) = 0x03EF4EDD Motor_Spd=3934.797
[530010] DC_BUS_POWER_PU (0x0714) = 0xF3320000 Motor_Pwr=6079.883
[motor 60+ok]
[8329_dump+ok]
[535988] ISD_CONFIG (0x0080) = 0x7F404D06
[535992] MOTOR_STARTUP1 (0x0082) = 0x6C9265B8
[535996] MOTOR_STARTUP2 (0x0084) = 0x5A18B295
[536001] CLOSED_LOOP1 (0x0086) = 0x3025E600
[536005] CLOSED_LOOP2 (0x0088) = 0x02A1A428
[536009] CLOSED_LOOP3 (0x008A) = 0x34C92001
[536014] CLOSED_LOOP4 (0x008C) = 0x001AC953
[536018] CONST_SPEED (0x008E) = 0x30010000 KP=768/10000, KI=256/1M, Loop_mode=0 1:spd,2:pwr
[536026] CONST_PWR (0x0090) = 0x7D006400 M_spd=64000, M_pwr=1600
[536032] FAULT_CONFIG1 (0x0092) = 0x71783624
[536037] FAULT_CONFIG2 (0x0094) = 0x7C85C00A
[536041] 150_DEG_TWO_PH_PROFILE (0x0096) = 0x24DB7200
[536046] 150_DEG_THREE_PH_PROFILE (0x0098) = 0x48DB6946
[536052] REF_PROFILES1 (0x009A) = 0x032184A6
[536056] REF_PROFILES2 (0x009C) = 0x34C80AFC
[536061] REF_PROFILES3 (0x009E) = 0x4787D70C
[536065] REF_PROFILES4 (0x00A0) = 0x000C9932
[536070] REF_PROFILES5 (0x00A2) = 0x1F6BF200
[536074] REF_PROFILES6 (0x00A4) = 0x00708000
[536079] PIN_CONFIG1 (0x00A6) = 0x20600002
[536083] PIN_CONFIG2 (0x00A8) = 0x3E0020AA
[536087] DEVICE_CONFIG (0x00AA) = 0x27100008
[536091] GD_CONFIG1 (0x00AC) = 0x000200FC Dir= Uni, CSA=0
[536097] GD_CONFIG2 (0x00AE) = 0x00000000
[536101] GATE_DRIVER_FAULT_STATUS (0x00E0) = 0x00000000
[536106] CONTROLLER_FAULT_STATUS (0x00E2) = 0x00000000
[536111] SYS_STATUS1 (0x00E4) = 0x00F69920 Volt_mag=24.600, Motor_Spd(eHz)=59.816%
[536119] ALGO_CTRL1 (0x00E6) = 0x00000000
[536123] DEVICE_CTRL (0x00E8) = 0x00000000
[536127] SYS_STATUS2 (0x00EA) = 0x20010751 State=0x2, Motor_Spd(eHz)=187.300
[536134] SYS_STATUS3 (0x00EC) = 0xFFFFAD43
[536141] INPUT_DUTY (0x040C) = 0x26738000 In_duty=60.080%
[536147] CURRENT_DUTY (0x0512) = 0x2677538B Curr_duty=60.103%
[536153] SET_DUTY (0x0522) = 0x26738000 Set_duty=60.080%
[536158] MOTOR_SPEED_PU (0x05CE) = 0x02FFEACE Motor_Spd=2999.677
[536164] DC_BUS_POWER_PU (0x0714) = 0xF66D4000 Motor_Pwr=6160.669
[motor 30+ok]
[8329_dump+ok]
[542702] ISD_CONFIG (0x0080) = 0x7F404D06
[542706] MOTOR_STARTUP1 (0x0082) = 0x6C9265B8
[542714] MOTOR_STARTUP2 (0x0084) = 0x5A18B295
[542718] CLOSED_LOOP1 (0x0086) = 0x3025E600
[542723] CLOSED_LOOP2 (0x0088) = 0x02A1A428
[542727] CLOSED_LOOP3 (0x008A) = 0x34C92001
[542731] CLOSED_LOOP4 (0x008C) = 0x001AC953
[542736] CONST_SPEED (0x008E) = 0x30010000 KP=768/10000, KI=256/1M, Loop_mode=0 1:spd,2:pwr
[542744] CONST_PWR (0x0090) = 0x7D006400 M_spd=64000, M_pwr=1600
[542750] FAULT_CONFIG1 (0x0092) = 0x71783624
[542755] FAULT_CONFIG2 (0x0094) = 0x7C85C00A
[542759] 150_DEG_TWO_PH_PROFILE (0x0096) = 0x24DB7200
[542764] 150_DEG_THREE_PH_PROFILE (0x0098) = 0x48DB6946
[542770] REF_PROFILES1 (0x009A) = 0x032184A6
[542774] REF_PROFILES2 (0x009C) = 0x34C80AFC
[542779] REF_PROFILES3 (0x009E) = 0x4787D70C
[542783] REF_PROFILES4 (0x00A0) = 0x000C9932
[542788] REF_PROFILES5 (0x00A2) = 0x1F6BF200
[542792] REF_PROFILES6 (0x00A4) = 0x00708000
[542797] PIN_CONFIG1 (0x00A6) = 0x20600002
[542801] PIN_CONFIG2 (0x00A8) = 0x3E0020AA
[542805] DEVICE_CONFIG (0x00AA) = 0x27100008
[542809] GD_CONFIG1 (0x00AC) = 0x000200FC Dir= Uni, CSA=0
[542815] GD_CONFIG2 (0x00AE) = 0x00000000
[542819] GATE_DRIVER_FAULT_STATUS (0x00E0) = 0x00000000
[542824] CONTROLLER_FAULT_STATUS (0x00E2) = 0x00000000
[542829] SYS_STATUS1 (0x00E4) = 0x00F34D18 Volt_mag=24.300, Motor_Spd(eHz)=30.116%
[542837] ALGO_CTRL1 (0x00E6) = 0x00000000
[542841] DEVICE_CTRL (0x00E8) = 0x00000000
[542845] SYS_STATUS2 (0x00EA) = 0x200103AF State=0x2, Motor_Spd(eHz)=94.300
[542852] SYS_STATUS3 (0x00EC) = 0xFFFFD742
[542859] INPUT_DUTY (0x040C) = 0x13360000 In_duty=30.017%
[542865] CURRENT_DUTY (0x0512) = 0x133F0000 Curr_duty=30.072%
[542871] SET_DUTY (0x0522) = 0x13360000 Set_duty=30.017%
[542876] MOTOR_SPEED_PU (0x05CE) = 0x01811CC1 Motor_Spd=1504.345
[542882] DC_BUS_POWER_PU (0x0714) = 0xFB33C000 Motor_Pwr=6280.054
[motor 10+ok]
[8329_dump+ok]
[551085] ISD_CONFIG (0x0080) = 0x7F404D06
[551089] MOTOR_STARTUP1 (0x0082) = 0x6C9265B8
[551093] MOTOR_STARTUP2 (0x0084) = 0x5A18B295
[551098] CLOSED_LOOP1 (0x0086) = 0x3025E600
[551102] CLOSED_LOOP2 (0x0088) = 0x02A1A428
[551106] CLOSED_LOOP3 (0x008A) = 0x34C92001
[551111] CLOSED_LOOP4 (0x008C) = 0x001AC953
[551115] CONST_SPEED (0x008E) = 0x30010000 KP=768/10000, KI=256/1M, Loop_mode=0 1:spd,2:pwr
[551123] CONST_PWR (0x0090) = 0x7D006400 M_spd=64000, M_pwr=1600
[551129] FAULT_CONFIG1 (0x0092) = 0x71783624
[551134] FAULT_CONFIG2 (0x0094) = 0x7C85C00A
[551138] 150_DEG_TWO_PH_PROFILE (0x0096) = 0x24DB7200
[551143] 150_DEG_THREE_PH_PROFILE (0x0098) = 0x48DB6946
[551149] REF_PROFILES1 (0x009A) = 0x032184A6
[551153] REF_PROFILES2 (0x009C) = 0x34C80AFC
[551158] REF_PROFILES3 (0x009E) = 0x4787D70C
[551162] REF_PROFILES4 (0x00A0) = 0x000C9932
[551167] REF_PROFILES5 (0x00A2) = 0x1F6BF200
[551171] REF_PROFILES6 (0x00A4) = 0x00708000
[551176] PIN_CONFIG1 (0x00A6) = 0x20600002
[551180] PIN_CONFIG2 (0x00A8) = 0x3E0020AA
[551184] DEVICE_CONFIG (0x00AA) = 0x27100008
[551188] GD_CONFIG1 (0x00AC) = 0x000200FC Dir= Uni, CSA=0
[551194] GD_CONFIG2 (0x00AE) = 0x00000000
[551198] GATE_DRIVER_FAULT_STATUS (0x00E0) = 0x00000000
[551203] CONTROLLER_FAULT_STATUS (0x00E2) = 0x00000000
[551208] SYS_STATUS1 (0x00E4) = 0x00ED19B8 Volt_mag=23.700, Motor_Spd(eHz)=10.047%
[551216] ALGO_CTRL1 (0x00E6) = 0x00000000
[551220] DEVICE_CTRL (0x00E8) = 0x00000000
[551224] SYS_STATUS2 (0x00EA) = 0x20010140 State=0x2, Motor_Spd(eHz)=32.000
[551231] SYS_STATUS3 (0x00EC) = 0xFFFFF8A1
[551238] INPUT_DUTY (0x040C) = 0x06740000 In_duty=10.083%
[551244] CURRENT_DUTY (0x0512) = 0x0677B608 Curr_duty=10.106%
[551250] SET_DUTY (0x0522) = 0x06488000 Set_duty=9.818%
[551255] MOTOR_SPEED_PU (0x05CE) = 0x00834C1F Motor_Spd=512.880
[551261] DC_BUS_POWER_PU (0x0714) = 0xFF204000 Motor_Pwr=6378.149
[28533] ISD_CONFIG (0x0080) = 0x7F404D06
[28537] MOTOR_STARTUP1 (0x0082) = 0x6C9265B8
[28542] MOTOR_STARTUP2 (0x0084) = 0x5A18B295
[28546] CLOSED_LOOP1 (0x0086) = 0x3025E600
[28550] CLOSED_LOOP2 (0x0088) = 0x02A1A428
[28554] CLOSED_LOOP3 (0x008A) = 0x34C92001
[28559] CLOSED_LOOP4 (0x008C) = 0x001AC953
[28563] CONST_SPEED (0x008E) = 0x30010000 KP=768/10000, KI=256/1M, Loop_mode=0 1:spd,2:pwr
[28571] CONST_PWR (0x0090) = 0x01900C80 M_spd=800, M_pwr=200
[28577] FAULT_CONFIG1 (0x0092) = 0x71783624
[28581] FAULT_CONFIG2 (0x0094) = 0x7C85C00A
[28585] 150_DEG_TWO_PH_PROFILE (0x0096) = 0x24DB7200
[28590] 150_DEG_THREE_PH_PROFILE (0x0098) = 0x48DB6946
[28595] REF_PROFILES1 (0x009A) = 0x032184A6
[28600] REF_PROFILES2 (0x009C) = 0x34C80AFC
[28604] REF_PROFILES3 (0x009E) = 0x4787D70C
[28608] REF_PROFILES4 (0x00A0) = 0x000C9932
[28613] REF_PROFILES5 (0x00A2) = 0x1F6BF200
[28617] REF_PROFILES6 (0x00A4) = 0x00708000
[28621] PIN_CONFIG1 (0x00A6) = 0x20600002
[28625] PIN_CONFIG2 (0x00A8) = 0x3E0020AA
[28629] DEVICE_CONFIG (0x00AA) = 0x27100008
[28634] GD_CONFIG1 (0x00AC) = 0x000200FC Dir= Uni, CSA=0
[28639] GD_CONFIG2 (0x00AE) = 0x00000000
[28643] GATE_DRIVER_FAULT_STATUS (0x00E0) = 0x00000000
[28648] CONTROLLER_FAULT_STATUS (0x00E2) = 0x00000000
[28653] SYS_STATUS1 (0x00E4) = 0x00F0198A Volt_mag=24.000, Motor_Spd(eHz)=9.977%
[28661] ALGO_CTRL1 (0x00E6) = 0x00000000
[28665] DEVICE_CTRL (0x00E8) = 0x00000000
[28669] SYS_STATUS2 (0x00EA) = 0x20010140 State=0x2, Motor_Spd(eHz)=32.000
[28676] SYS_STATUS3 (0x00EC) = 0xFFFFF880
[28683] INPUT_DUTY (0x040C) = 0x06578000 In_duty=9.909%
[28688] CURRENT_DUTY (0x0512) = 0x067F48C5 Curr_duty=10.152%
[28694] SET_DUTY (0x0522) = 0x06630000 Set_duty=9.979%
[28699] MOTOR_SPEED_PU (0x05CE) = 0x28FFCA8B Motor_Spd=512.490
[28705] DC_BUS_POWER_PU (0x0714) = 0xF6828000 Motor_Pwr=770.343
