Hi all,
We designed our custom DRV10987 board and we tryna start the motor but motor is dont working cause of given overcurrent issue, no short circuit between phases.. What is the primary problem?
Hi all,
Hi Ceyhun,
How much is the motor resistance? Can you share the PCB schematic?
Vishnu
PCB's motor driver part is below
Motor features:
Motor P/N is: EMAX BL2826
Motor phase to phase resistance : 0.3 Ohm
Motor KV: 800KV
Motor Pole Count: 14
Hi Ceyhun,
Schematic looks good. I think the current limit gets triggered due to low motor resistance. Can you program higher motor resistance (~0.8 ohms) and try again ? Also, can you share the register values ?
Vishnu
Hello Vishnu,
We solved it.
it happened because of motor. We edited motor paramaters, aspecially BEMF value and it worked.
