DRV8350: Questions about DRV8350S circuit connection
Part Number: DRV8350
Hi team,
I would like to ask you a question about the circuit connection of DRV8350S.
Should the 30pin GND of DRV8350S be connected to the power GND? Or should I connect it to signal GND?
  • Hi Yamadadai,
    Pin 30, GND, is recommended to be connected to the system-level ground of the PCB.  If you have a split ground architecture for your system, It should most likely be connected to the power ground.
    -Joshua
