Other Parts Discussed in Thread: INA253
My name is Jonah Yu, I am a researcher working on developing the electronics and software development for one of our motor control FuMos and ran into a problem with our current sensor feedback. I am using a PSoC 5LP development kit from Cypress as the controller for the closed loop. For the inverter I am using a half-bridge with gate driver on an evaluation board. For the current-shunt sensor I am using TI's INA253EVM evaluation board. It seems when I place the sensor in series between the midpoint of the half bridge (Vsw) and the load, the current values are incorrect. They are than the power supply's current limit (500mA). However, when the sensor is placed in series between the power supply positive terminal and the high point of the half bridge (Vin+), the value agrees with the current value on the power supply. Is there a conventional place to put the INA253EVM for high side sensing in a closed current PI controlled loop? I have seen the manual place the sensor between the half-bridge midpoint and the load, but the current values do not seem to match with hand calculations and the current from the power supply for the drive inverter. The PWM frequency is about 122kHz with a period of 8.146us.
