I would like to know which formula is suitable for width trace calculation of the gate signals.
king regards,
Nikos
king regards,
Nikos
Hi Nikos,
Please refer to this app note regarding Best Practices for Board Layout specifically section 4.
Also here is a tool by DigiKey:
https://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-pcb-trace-width
Yara
Thank you for your reply. However, we had a discussion about this topic with your colleagues 1-2 years ago, and unfortunately, I cannot find the email. The main consideration was that if the IDRIVENP setting is set to 120mA, then with a high inductance of the gate trace, the equation V=Ldi/dt would result in a high voltage on the trace due to the very small dt. Therefore, I need to be cautious about the inductance of the trace, but I'm unsure if I can find this information on Digi-Key.
king Reards,
Nikos
Hi Nikos,
I'll have to discuss this with my team, I'll provide an update soon.
Yara
Hi Nikos,
As a rule of thumb you can use the following to get an estimate of the inductance of a trace: 20nH / 2.5cm.
This is not a calculation to get the exact inductance of the trace because other factors such as thickness, width, length, and material can influence resistance, capacitance, and inductance so this is just an estimation.
Yara
Hi Yara, thank you for your reply but I have posted an other question.
I asked the accepted inductance for the traces by the GHx and GLx pins on the drv8304.
King Regards,
Nikos
Hi Nikos,
I discussed your question with my team and there is not an "accepted inductance for the traces by the GHx and GLx pins on the drv8304" that we can provide. The best we can suggest is to keep that inductance as low as possible.
If you meant that you wanted to know what the inductance of the GHx and GLx pins on the drv8304 are then that is also information we do not have unfortunately.
Ultimately the conclusion we came to is that inductance on those traces and pins should be as small as possible otherwise you could run into issues in the future.
Yara
