Part Number: DRV8935
in the datasheet I can't find how the current is sensed. Through low side FET or high side FET or both?
If I use it as four independent half bridge, is it true that no matter I connect the load from OUT to VM or OUT to GND, the current could be sensed within the device?
And if a resistor load is connected from OUT to GND, and the Itrip<VM/Rload, when IN=1(means high side FET on), the trip point will be reached soon, will the high side FET be turned off even if IN is still 1? Will it try to turn on high side FET again or the high side FET will be latched off? When will the high side FET be turned on again?
