How many seconds after the VM supply reaches 4.35V does the VM undervoltage lockout function activate?
When observing the waveform on an oscilloscope, the timing of the VM supply reaching 4.35V and the nFAULT pin going low was not the same.
Thank you for your questions.
VM UVLO react ~10us range as datasheet deglitch time, therefore seconds range delay should not happen. UVLO threshold should not be exact 4.35V, it could be a little higher or lower depending on parts. Therefore you may see some timing gap of nFAULT from your 4.35V timing.
regards
Shinya Morita
Thank you for your response.
What is the minimum voltage for the UVLO threshold? The datasheet provides typical and maximum values, but the minimum value is left blank.
No min SPEC is available, but we can consider ~4.20V min as reference information.
regards
Shinya Morita
