Hello, team
I want to confirm by calculation that Qgs and Qgd will pass within the set time of "OCP_DEG" register after Gate=On, and that overcurrent will not be detected.
I checked the following documents.
www.ti.com/.../slva714d.pdf
1.4 Simple Slew-Rate Calculation
From this document, I understand a simple formula for calculating the slew rate.
I want to use a formula similar to this calculation to make sure that overcurrent is not detected.
If you have any ideas to calculate the time for the QGS period, please share with me.
For example, is this formula correct?
Divide the sum of Qgs and Qgd by Isource.
・tSLEW = (QGS+QGD) ÷ Isource
best regards
manabu
