MCF8316C-Q1: Application issues.
Expert 2020 points
Part Number: MCF8316C-Q1
Hi Team,
Using MCF8316C1VQRGFRQ1,
What programmer is used for this IC?
The customer is preparing for production and needs to provide a burning tool.
  • Hi Reed,
    I assume you are referring to a gang programmer like the MSP-GANG?
    If you are, we currently do not have a gang programmer available for our MCX devices but we are in the process of developing a MCx gang programmer board. When would your customer need the programming tool?
    As a current solution, the MCF8316C's can be individually programmed by using the code example in our Program MCx BLDC motor driver through I2C FAQ. The only change to the code will be modifying the eeprom_regmap array to your desired settings.
    Joshua
