DRV8316C-Q1: Isolated power supply
Part Number: DRV8316C-Q1
Other Parts Discussed in Thread: DRV8316C
Hello
Is there anything to consider regarding running the controller from an isolated power supply?
That is, interfacing DRV8316C with a control device running off a galvanically-isolated power supply with digital isolation on all I/O (PWM / Current sense etc).
  • Hi Philip,
    Thank you for posting to our forum!
    Please allow me to look into this isolation question and follow-up up shortly this week.
    -Joshua
  • Hi Philip,
    I apologize for the delay in this response.
    If this inquiry is still open, please find my response below:
    There should be no issue regarding this isolation if the connections are I/O low voltage. If interfacing with the powerstage or supply GNDs (higher-voltage GND) then it may be beneficial to have a logic/digital GND plane and a higher voltage/system GND plane to ensure high and low voltages on either system (driver and MCU) are kept reasonably isolated.
    Thank you again for your patience and Best Regards,
    -Joshua
