DRV8714-Q1: SDO
Part Number: DRV8714-Q1
Hi team,
Could you please help review below customer's question and give some comments? Thanks!
The customer's SBC shares CLK, SDO, SDI signal lines with DRV8714S-Q1. The customer thinks that the SDO pin of DRV8714-Q1 will incorrectly pulls the SDO down when there is a no chip select signal, resulting in MCU and SBC communication anomaly, eventually resulting in SBC to constantly reset the MCU.
The customer has verified as follows, they removed the resistor between the SDO pin of the DRV8714-Q1and the shared SDO wire, replaced it with a switch that is set to closed;
Waveform 1: the SDO pin of DRV8714-Q1 will incorrectly pulls the SDO down when there is a no chip select signal, resulting in MCU and SBC communication anomaly.
Waveform 2: Switch off, shared SDO line signal OK, SBC no longer resets the MCU, and the MCU can send the message normally.
Thank you!
Ivy
