Hi team,
In D/S, it is said that user should delay 1ms before applying PWM when nSLEEP is switching low to high.
If this interval is shorter than 1ms, what type of trouble does occur?
Goto
Hi team,
Goto
Hi Goto,
Thanks for your question.
DRV8800 uses charge pump to generate a supply above VBB to drive the source-side DMOS gates. The 1ms time is given to stabilize the charge pump. This is needed for the turning ON of the DMOS FETs.
Ibinu
HI Ibinu,
Thank you for answer.
So, in the case below, does the charge pump stabilize gradually?
Or will the motor not run until nSLEEP reconfiguration?
>nSLEEP released
>(Wait<1msec)
>Through-up (PWM0% to 80%, 23.4kHz, 20msec)
>Constant speed (PWM80%, 23.4 kHz)
>Slew down (PWM80% -> 0%, 23.4kHz, 20msec)
>Nsleep setting ←Does the motor not move until this time?
If you have any question, please let me know.
Goto
Hi Goto,
Thanks for the follow up.
While the charge pump is stabilizing if the device is trying to run the motor, the charge pump might not rise to the required level. The VCP voltage level is internally monitored and, in the case of a fault condition, the outputs of the device are disabled.
Please let me know if this clarifies.
Ibinu
Hi Ibinu,
Thank you for reply.
i.e. if I input PMW without 1ms delay, VCP will not stabilize and the motor may never start, right?
Goto
Hi Ibinu,
Do you have any update?
Goto
Hi Goto,
You are right. Without the 1ms delay the motor might not start since the VCP voltage might not be enough to turn the FETs on.
Please let me know if this clarifies the question.
Ibinu
