MCT8329A: Motor Driver tuning issue with MCT8329A1I
Part Number: MCT8329A
I would like help tuning the TI MCT8329A1I  chip. We are currently trying to run a brushless air pump and we are having difficulty running it as fast as required. We can run the brushless pump with an external off the shelf motor driver board to our specification (max speed). The air pump has a maximum of 32000 rpm, rated to 18-26.5V, Max 4.3A.
thank you, Stuart
  • Hi Kesav,
    Can you provide pole pair of the motor.
    Did you try using default JSON?
    What is the max speed you are able to achieve? Are you seeing any fault or saturation?
    Please share your JSON file.
    Thanks and Best Regards
    Venkatadri S
  • Hello Venkatadri S,
    Thanks for the reply.
    The current consumption is approximately 1.634 Amps at 25.2V at the current max speed - although the pressure is well down on where it needs to be (about 50% of required)
    With a 3rd party driver running the pump at the maximum speed the current consumption is 2.51Amps
    I will find the duty cycle setting for our maximum pressure setting and advise in a second post.
    Please see below the pump drawing.
    We used the default settings from the TI tuning kit -
    Please find the JSON file below:
      "signature": "oneui-register-data",
      "data": [
            "idx": 0,
            "id": "isd_config",
            "value": "0x7F404D02"
            "idx": 1,
            "id": "motor_startup1",
            "value": "0x6C9265B7"
            "idx": 2,
            "id": "motor_startup2",
            "value": "0x332D3295"
            "idx": 3,
            "id": "closed_loop1",
            "value": "0x1025E600"
            "idx": 4,
            "id": "closed_loop2",
            "value": "0x02A1A418"
            "idx": 5,
            "id": "closed_loop3",
            "value": "0x34C92001"
            "idx": 6,
            "id": "closed_loop4",
            "value": "0x001AC953"
            "idx": 7,
            "id": "const_speed",
            "value": "0x30010000"
            "idx": 8,
            "id": "const_pwr",
            "value": "0x00000640"
            "idx": 9,
            "id": "150_deg_two_ph_profile",
            "value": "0x24DB7200"
            "idx": 10,
            "id": "150_deg_three_ph_profile",
            "value": "0x48DB6946"
            "idx": 11,
            "id": "ref_profiles1",
            "value": "0x032184A6"
            "idx": 12,
            "id": "ref_profiles2",
            "value": "0x34C80AFC"
            "idx": 13,
            "id": "ref_profiles3",
            "value": "0x4787D70C"
            "idx": 14,
            "id": "ref_profiles4",
            "value": "0x000C9932"
            "idx": 15,
            "id": "ref_profiles5",
            "value": "0x1F6BF200"
            "idx": 16,
            "id": "ref_profiles6",
            "value": "0x00708000"
            "idx": 0,
            "id": "algo_ctrl1",
            "value": "0x20000000"
            "idx": 1,
            "id": "device_ctrl",
            "value": "0x21DB8000"
            "idx": 0,
            "id": "ana_trim3",
            "value": "0x00000000"
            "idx": 1,
            "id": "ana_trim4",
            "idx": 2,
            "id": "ana_trim5",
            "idx": 3,
            "id": "ana_trim6",
            "idx": 4,
            "id": "ana_trim7",
            "idx": 5,
            "id": "ana_trim8",
            "idx": 6,
            "id": "ana_trim9",
            "idx": 7,
            "id": "ana_trim10",
            "idx": 0,
            "id": "fault_config1",
            "value": "0x71783604"
            "idx": 1,
            "id": "fault_config2",
            "value": "0x7085C00A"
            "idx": 0,
            "id": "gate_driver_fault_status",
            "idx": 1,
            "id": "controller_fault_status",
            "idx": 0,
            "id": "gd_config1",
            "value": "0x000600FC"
            "idx": 1,
            "id": "gd_config2",
            "idx": 0,
            "id": "pin_config1",
            "value": "0x20600004"
            "idx": 1,
            "id": "pin_config2",
            "value": "0x3E0020AA"
            "idx": 2,
            "id": "device_config",
            "value": "0x27100008"
            "idx": 0,
            "id": "sys_status1",
            "idx": 1,
            "id": "sys_status2",
            "idx": 2,
            "id": "sys_status3",
  • Hi Kesav,
    Thanks for providing requested details.
    I will look into the details and update you by tomorrow.
    Venkatadri S
  • Hi Kesav,
    In the JSON file you have shared two configurations looks not proper, CONST_PWR  MAX Speed field are 00.
    Can you try the default JSON as is?
      "data": [
            "idx": 0,
            "id": "isd_config",
            "idx": 1,
            "idx": 2,
            "idx": 3,
            "idx": 4,
            "value": "0x02A1A428"
            "idx": 5,
            "idx": 6,
            "idx": 7,
            "idx": 8,
            "id": "const_pwr",
            "value": "0x1F400640"
            "idx": 9,
            "idx": 10,
            "idx": 11,
            "idx": 12,
            "idx": 13,
            "idx": 14,
            "idx": 15,
            "idx": 16,
            "idx": 0,
            "id": "algo_ctrl1",
            "idx": 1,
            "idx": 0,
            "id": "ana_trim3",
            "idx": 1,
            "id": "ana_trim4",
            "idx": 2,
            "id": "ana_trim5",
            "idx": 3,
            "id": "ana_trim6",
            "idx": 4,
            "id": "ana_trim7",
            "idx": 5,
            "id": "ana_trim8",
            "idx": 6,
            "id": "ana_trim9",
            "idx": 7,
            "id": "ana_trim10",
            "idx": 0,
            "idx": 1,
            "value": "0x7C85C00A"
            "idx": 0,
            "idx": 1,
            "idx": 0,
            "id": "gd_config1",
            "idx": 1,
            "id": "gd_config2",
            "idx": 0,
            "value": "0x20600002"
            "idx": 1,
            "idx": 2,
            "idx": 0,
            "idx": 1,
            "idx": 2,
    Venkatadri S
