Hi team ,
could you pls help to check the ocp deglitch time requirements when VM below 20V
Hi team ,
Thank you for your question. Our expert will feedback to you within 24hours.
Hi Eric,
This table is for the following conditions Vm = 4.5 - 32 V:
Keerthi
Hi Keerthi,
is there any feedback on this?
we need know the deglitch time when VM is below 20V
Hi Eric,
I checked with design. There is not limitation for Vm < 20 as mentioned. The 20 is also not a hard cutoff fyi it is more of a gradient. The reason for the limitation for Vm > 20 is due to hot spots forming and the thermal sensors not being able to respond fast enough, which could damage the Fets.
Keerthi
Hi Keerthi,
actually , I knew this requirements based on the thermal performance in case of over power. so I think there must be some calculator for this
Hi Eric,
This is based of simulations we ran internally when PG'ing this device. Please follow the guidance as discussed above. Let me know if there is any confusion on the customer side, but the note itself is clear.
Keerthi
