What is the max leakage current expected from OUT pin when OUT pin is in Hi-Z state
Thank you for your question. will feedback to you within 24hours
Thank you for your question. Please refer R_HiZ SPEC to estimate max leakage.
regards
Shinya
Hello Shinya,
In standby mode driver OUT will be in HI-Z state , but here in TEST CONDITION it is shown to be 13.5V. Why?
Or my understanding is not correct?
Thank you for your questions. This device is mainly targeting automotive, then 13.5V typ battery voltage range. That is why 13.5V is used. Even in stand by mode, battery voltage could be supplied ~13.5V.
OUTx pin has diode path to VM with abs max= VM+0.9V. This is reason SPEC condition is added as VM=OUTx=13.5V.
