DRV8706-Q1: Offline Diagnostic Enable Pull-up and Pull-down
Part Number: DRV8706-Q1
For the build in offline diagnostics the DRV8706S-Q1 has multiple current sources integrated and pull-up and pull-down can be activated. If we switch on PU_SH1 and PD_SH2 at the same time (which then causes a current to flow through the load), can we assume that the voltage is always set in the "middle" of the drain voltage?
Viktor
