MCF8315A: Porting from MCF8315A to DRV10983 brushless driver
Part Number: MCF8315A
Other Parts Discussed in Thread: DRV10983
i want to drive the Maxon brushless motor 6215.ECX FL32S KLA STD 24V b81626dfef55_1.pdf at 200rps on 28V but when I use the DRV10983 driver chip I can only reach 160rps, whereas using the MCF8315A I can reach 205rps with a 28V supply.  The question is how should I change the configuration and parameters for the MCF8315A to get the motor running at 200rps on the DRV10893?
I have attached data sheets and configuration file
"signature":"oneui-register-data",
"data":[
"idx":0,
"id":"ISD_CONFIG",
"value":"0x64738C20"
"idx":1,
"id":"REV_DRIVE_CONFIG",
"value":"0xA8200000"
"idx":2,
"id":"MOTOR_STARTUP1",
"value":"0x0B6807D0"
"idx":3,
"id":"MOTOR_STARTUP2",
"value":"0xA306600C"
"idx":4,
"id":"CLOSED_LOOP1",
"value":"0x0D3203B5"
"idx":5,
"id":"CLOSED_LOOP2",
"value":"0x9BADA192"
"idx":6,
"id":"CLOSED_LOOP3",
"value":"0x24EC8003"
"idx":7,
"id":"CLOSED_LOOP4",
"value":"0x16D91C20"
"idx":8,
"id":"SPEED_PROFILES1",
"value":"0x00000000"
"idx":9,
"id":"SPEED_PROFILES2",
"idx":10,
"id":"SPEED_PROFILES3",
"idx":11,
"id":"SPEED_PROFILES4",
"value":"0x800D0000"
"idx":12,
"id":"SPEED_PROFILES5",
"idx":13,
"id":"SPEED_PROFILES6",
"idx":0,
"id":"FAULT_CONFIG1",
"value":"0xBBB80106"
"idx":1,
"id":"FAULT_CONFIG2",
"value":"0xFFD00888"
"idx":0,
"id":"INT_ALGO_1",
"value":"0xA433407D"
"idx":1,
"id":"INT_ALGO_2",
"value":"0x000001A7"
"idx":0,
"id":"PIN_CONFIG",
"idx":1,
"id":"DEVICE_CONFIG1",
"value":"0x00101462"
"idx":2,
"id":"DEVICE_CONFIG2",
"value":"0xC000F00F"
"idx":3,
"id":"PERI_CONFIG1",
"value":"0xC1C01F00"
"idx":4,
"id":"GD_CONFIG1",
"value":"0x9C450100"
"idx":5,
"id":"GD_CONFIG2",
"value":"0x80200000"
"idx":0,
"id":"GATE_DRIVER_FAULT_STATUS",
"idx":1,
"id":"CONTROLLER_FAULT_STATUS",
"idx":0,
"id":"ALGO_STATUS",
"value":"0x07E00004"
"idx":1,
"id":"MTR_PARAMS",
"value":"0xA1008A00"
"idx":2,
"id":"ALGO_STATUS_MPET",
"value":"0x13000000"
"idx":0,
"id":"ALGO_CTRL1",
"value":"0x20000000"
"idx":0,
"id":"ALGO_DEBUG1",
"value":"0x80000000"
"idx":1,
"id":"ALGO_DEBUG2",
"idx":2,
"id":"CURRENT_PI",
"value":"0x03010301"
"idx":3,
"id":"SPEED_PI",
"idx":4,
"id":"DAC_1",
"idx":5,
"id":"DAC_2",
"idx":0,
"id":"ALGORITHM_STATE",
"idx":1,
"id":"FG_SPEED_FDBK",
"value":"0x00D34EEB"
"idx":2,
"id":"BUS_CURRENT",
"idx":3,
"id":"PHASE_CURRENT_A",
"value":"0x00040000"
"idx":4,
"id":"PHASE_CURRENT_B",
"idx":5,
"id":"PHASE_CURRENT_C",
"value":"0xFFF80000"
"idx":6,
"id":"CSA_GAIN_FEEDBACK",
"value":"0x00010002"
"idx":7,
"id":"VOLTAGE_GAIN_FEEDBACK",
"idx":8,
"id":"VM_VOLTAGE",
"value":"0x03C08000"
"idx":9,
"id":"PHASE_VOLTAGE_VA",
"idx":10,
"id":"PHASE_VOLTAGE_VB",
"idx":11,
"id":"PHASE_VOLTAGE_VC",
"idx":12,
"id":"SIN_COMMUTATION_ANGLE",
"value":"0x0493F954"
"idx":13,
"id":"COS_COMMUTATION_ANGLE",
"value":"0xF97279E4"
"idx":14,
"id":"IALPHA",
"value":"0xFFD00000"
"idx":15,
"id":"IBETA",
"value":"0xFFC8930A"
"idx":16,
"id":"VALPHA",
"value":"0xFFDF5F0E"
"idx":17,
"id":"VBETA",
"value":"0xFFCE8712"
"idx":18,
"id":"ID",
"value":"0x0005C0B5"
"idx":19,
"id":"IQ",
"value":"0x0049120F"
"idx":20,
"id":"VD",
"value":"0xFFFE69BC"
"idx":21,
"id":"VQ",
"value":"0x003B4A1C"
"idx":22,
"id":"IQ_REF_ROTOR_ALIGN",
"idx":23,
"id":"SPEED_REF_OPEN_LOOP",
"idx":24,
"id":"IQ_REF_OPEN_LOOP",
"value":"0x09997560"
"idx":25,
"id":"SPEED_REF_CLOSED_LOOP",
"idx":26,
"id":"ID_REF_CLOSED_LOOP",
"idx":27,
"id":"IQ_REF_CLOSED_LOOP",
"value":"0x003A244B"
"idx":28,
"id":"ISD_STATE",
"value":"0x00000005"
"idx":29,
"id":"ISD_SPEED",
"idx":30,
"id":"IPD_STATE",
"idx":31,
"id":"IPD_ANGLE",
"value":"0x0803A989"
"idx":32,
"id":"ED",
"idx":33,
"id":"EQ",
"idx":34,
"id":"SPEED_FDBK",
"idx":35,
"id":"THETA_EST",
"idx":0
