Other Parts Discussed in Thread: DRV8846,
Hi, TI expert
A customer is using the attached IX471AQ (Intrixchip) in an application (CCTV).
IX471AQ_DATASHEET_V01-130215.pdf
The IX471AQ(Intrixchip) has an input voltage range of 3V~5V, and the customer needs to change the input voltage to 6V for operation.
Is there a TI solution as a possible replacement at 6V input voltage?
Please check. Thank you.
