DRV8334: Phase Comparators in 6x PWM Mode
Part Number: DRV8334
Would you be able to clarify if the phase comparator can be used in 6x pwm mode? Having not seen anything but the description and block diagram , I am having a hard time understanding if the phase comparators can be used without taking away the PWM function for the INLX pins ( The document seems to indicate yes , but I want to confirm). We would benefit from shutting down the system but not at the expense of 6x PWM. Could you also help us understand if the threshold for this gets set internally or if something needs to be done externally?
Thank you, Keith
