I am investigating using the DRV8320H as a possible replacement for a different motor driver we're using that has gone obsolete.
We are trying to make the change without doing a software change if at all possible (which means the SPI version is not really an option).
My question is specific to the GDF since this appears to be a latching fault.
I found this comment in another thread...
"The only way you can clear the fault on the hardware version is by toggling the ENABLE pin to reset the device. There is no retry time because this is a latching fault."
Will putting the device to sleep (de-asserting Enable) also clear a GDF that has occurred? Or does it only clear on a reset pulse?
