Part Number: DRV3901-Q1
Hi team,
1. Customer feedbacked that the CONFIG_CRC_W was triggered after they configure the CONFIGx register. And they checked the read register value can match with write register value.
CONFIG_CRC_W can be triggered every time. Could you provide some ideas to figure out the root cause and how should we solve this warning problem.
2. Regarding to off-state diagnostic configuration 1&2 register, could you provide some guidance or documents that how should we set these different parameter? For example, for OFF_DIAG_WK_PD_VSEL, which application scenario we should use 1.5V? Or 1.8V?
Thanks!
Ethan Wen
