Part Number: DRV8328
The recommended operating conditions of the DRV8328 specify Itrickle (Trickle charge pump external load current) as 2 uA. The datasheet later suggests adding a 10k-100k external gate pull-down to ensure the gates stay off under all conditions, this is obviously more than 2 uA. I assume this is just a specification on how much current the charge pump can provide rather than a limit that needs to be followed.
My question is: If significantly more than 2 uA of external load is present, will the bootstrap under-voltage fault detection be triggered or will the device fall back to a lower duty cycle mode?
